Bc 296 D
FireCop
Retired Public Safety Grunt
Statesville, NC
The BC296D will not decode & display the system ID. The BCD396T & newer Uniden scanners should decode the system ID.
garys
Central Texas
Mot ID refers to the talk group ID, not the system ID. Since the 296 doesn't display that information you wont' see it as Firecop wrote.
Gary
williams63
Mississauga , Canada
Ok , thx...my Pro 87 will have to do that job I guess,...also Ill answer my own question , there is no way to use 800 Mhz CC mode onoy on a EDAC system ?
And the reason I asked about the SysID was in a search mode ( IE : 140 - 144 ) I find a Contraol Channel , it appears like it wants to to display the SYS ID...hence the MOT ID:_ _ _ _ _ _
Tg's display fine....Hmmm ok
Q# 3 : I saw an upgrade for this scanner..tho the info on what it can do , was a little vauge...what does the upgrade do for us 296D owners ?
loumaag
Silent Key - Aug 2014
Katy, TX
EDACS systems, by definition, are Logical Channel Number systems. The channel numbers available are 1 - 25, so there cannot be a table set up that covers all the possible frequency pairs in the 800 MHz band. Hence the table is you putting the correct frequency in the correct LCN slot, so no there is no such thing as CCh Mode for EDACS (or LTR for that matter).
When monitoring a CCh in manual or hold mode, a lot of radios will display the TG's being granted channels as the channel grant is made.
Depends on what download/upgrade you are talking about. They all have been discussed at one time or another here in Uniden Forum.
williams63
Thank you Lou: I tried to search out the " BCD296Dv3.29 " Upgrade , and it didnt show much...Im not sure ehat it is suppose to Upgrade...any ideas would be much appreaciated .
Thx in advance.
loumaag
Katy, TX
Thx in advance.
That was the "Detroit" issue fix. Although firmware updates always contain the previous "fixes" also so it is a good idea to apply them. The Detroit problem was due to the P25 system there being modified during the Super Bowl to not "advertise" the channel line up, but rather use an "implicit" channel line up.
