BC235 audio
winpa
I picked up an old scanner at a garage sale a BC235
The audio is very poor to the point You can not hear
the radio in your car with the windows down
Does anyone know if this is a problem with this
model or is it just this radio I bought.
Also it eats up batteries very fast within an hour or so
I did not pay to much so I am not real concerned
Any help
DaveH
Ottawa, Ont.
The BC235 audio doesn't seem to be very loud to begin
with (normal). That the battery lasts only a short time
indicates it has a bad cell. After charging, the other
three cells will allow it to operate for a short time.
This may make the audio worse. Check out the battery
voltage when it cuts out. A normal pack would be around
4v or a bit higher.
Dave
cubn
Search, Listen and Submit
Marion/Johnson County, IN
The maximum audio output on the BC235xlt is 180 mW. The BCD396T is listed at 400 mW. A Motorola portable has 500 mW audio output. Still, the BC235 should be loud enough to hear.
You can order replacement battery packs online.
winpa
Bc235
Thanks for the helpfull info
I tried using the power adapter with the radio
and the audio is no better
I tried using an external speaker and it is even worse
Is the volume limited with the headphone jack?
Any thoughts
bwhite
Carroll County, MD
Think I read something about a resistor or capacitor on the earphone jack that limits the volume so-as to protect users from destroying their hearing. If you can get to the innards in that case you can clip the resistor or cap out of the circuit.
winpa
Bc235
Thanks for the info could you be more specific I can get to the inside of the case to the
speaker
bwhite
Carroll County, MD
Don't have it, use Google or there may be mucho info on this site if you use the many search features available.
