wr7agt
Hello South Dakotans,
I am in Helena Montana and we are about to launch the first APCO 25 system that will eventually be a statewide system much like yours.
I just bought a BC296D in preparation for the changeover on Feb 1 for the Lewis and Clark county area.
It is a VHF 5 (soon 6) site system, Smartnet, Smartzoneish in that all the sites are tied together via Microwave. I am assuming that trunking affiliation will cause voice channels at each site to come on if a talk group is used and one or more radios have affiliated on the site. So far, I know the Control Channel at each site, as well as the voice channels at each site. So far, the Control Channels have remained constant on one freq, but very occasionally and for a very short time, I have heard the Control Channel switch to one of the other voice channels. Most of the sites only have 3 frequencies anyway, one has 5.
So now to programming and questions. The manual that I have read on-line talks about the need, on VHF Trunked systems, for a base, space, and offset in order to work. The lowest frequency from all 5 sites is 154.340, and happens to be a Control Channel. I have seen reference to this base space offset thing and understand that the "space" is likely to be 15Khz as all the freqs are currently using standard VHF channels, and go as high as 159.465. Thus, 154.340 to 159.465 is the range in which all channels are found.
How do you guys program this base, space, offset for your systems and is the base freq the lowest they use, or some frequency below the 154.34 channel?
Space is assuming, 15
and then I see the 380 as a "default" for the "frequency" entry, but may not be correct.
And now for an operational question. If I had a XTS I would know how the smartzone works to keep a radio affiliated with a site and talkgroup, but not a Uniden.
Would it be wise to program all five sites in one bank, control channels and all, or each site in a seperate bank? If all in one bank, will I be able to stay with a talkgroup as it moves from site to site, if it moves? In the beginning there will be very few talk groups in use, but I guess the question is, can the 296 scan all the control channels and lock to a talk group regardless of which site or sites is being used?
Any help from those experiencing VHF APCO 25 systems would be greatly appreciated. The scanner arrives tomorrow (17th), so I have time to play, but, there is no activity yet other than the control channels in use at each site.
Thanks,
Tom
Thanks,
Tom
