BCD536HD SD card stuck in it's card reader
DomW
St. Clairsville, Ohio
BCD536HD SD card stuck in it's card reader. Its in and tilted up so I can't get tweezers in to pull it out, and I worry that that would damage the radio's card reader further. Also when inserting the card before it became stuck, the card could slide to either side and rarely would click in place even when straight in. Being an electronics tech I opened up the radio to hopefully remove the card and see what is wrong or replace the card reader but I do not see how to remove the board it is on from the metal frame it is held in with. Any suggestions?
Dom
DomW
Great idea but no. I tried pushing on the card again hoping it might pop out but it went in and disappeared. It seems the problem was that the card was going in above the card cage. Not sure why this happened as I have always been very careful inserting these cards.
Ubbe
Stockholm, Sweden
The same problem happened to me but I managed to pull out the card by grabbing it with a tiny miniature screwdriver. But then it was still a tiny bit reachable with the screwdriver at an angle from the top.
/Ubbe
