kskarma
I have (3)- BCT-8's that I have owned for 5-6 years and after about that length of time, they all have developed an audio problem when trunking...and ONLY when trunking. The best way I can describe it is like a radio that is tuned just a bit 'off-frequency'...or when you are hearing a Single Sideband ham on a regular shortwave radio. You can kind of make out most of the words, but they are not as clear as they have been...
SO...for the first two of my BCT-8's, I sent them off to Bearcat service and for the standard fee ($50 as I recall), they repaired them and they have worked fine ever since...this was within the last year or so for these two that I sent them.
This question is for the true tekkies on here? Is getting these back to correct operation on Trunking just a matter of a bit of alignment, or do you think some component was actually replaced? The 'Repair Tag' does not shed much light on this...I think it just said..."Repaired and Tested"... IF...it is just a matter of tweaking an adjustment in the scanner, I am competent to do that...but I would need to know WHICH coil or pot to adjust...assuming that the component is accessible..
If no one has any actual expertise about this, I will just send this BCT-8 (Number 3..!) off to Bearcat and cough up the $50 for the service. Being a bit cheap...and having some 'experimental urge', I would not mind trying to fix it myself...and pocket the $$$$$...
