prcguy
A typical scanner Discone like the Diamond 3000 is excellent for VHF through UHF, but starting somewhere in the 400-500Mhz range the pattern starts to raise above the horizon and at 700/800 it points high enough above the horizon where reception suffers. My recommendation is to stay with the Diamond 3000 and don't install its top whip. Then get a second antenna that covers 700/800MHz and use a diplexer to combine them onto one feedline. If stuff above 800Mhz interests you there are small Discones that cover about 300-400MHz to well over 2GHz that will supplement the Diamond 3000.
Ok and any suggestions?
Would the OmniX be better?
I already have LDF4_50A feedline, about an 90-100 ft run.
I also have an 800Mhz Yagi but it is a stationary mount, I thought about mounting it onto my mast with my TV rotator.
