SDS100/SDS200: Bluetooth Transmitter & Earpiece Solution for SDS 100 & 200 (Again)
Unidener
ENC
I'm looking for this solution as well but I got a BT Tx that will Tx to my Radio via BT just fine.
My problem is that I have 2 sets of BT head/earphones that do not appear to "Pair" to the BT Tx.
Any suggestions on a BT Tx that will Tx Bt and will allow ear/headphones to Pair to it as well?
Thanks!
Unidener
ENC
Seeing how no Uniden scanner has built-in BT I don't see how this applies...but I could be wrong.
I'm using a BT/FM Transmitter that plugs into the headphone jack of the SDS100..... I'm just having problems connecting to the transmitter from my BT earphones. Which one is not cooperating? Everything connects well with my phone but trying to get something that will transmit from the scanner BT to my BT earphones.
All I have to work with on the earphones is a blinking light on one pair and the other does not even have lights.....
I was hoping to find someone that is already doing this and wanted to see what gear they are using......
GILLIG40
Northwest, Ohio
Unidener
ENC
This is what I have been using for the last two years. I have had no issues. Using with a SDS200, BCD996T and out the external speaker jack on a Unication amplified charger.
Bluetooth
Earbuds
And if you should be looking for an Bluetooth external speaker this one works great
The earbuds and speaker have great vocal audio. No booming bass.
Great....just to confirm...you can BT from your SDS200 directly to your Earbuds....correct?
Unidener
ENC
Yes. Plug the Bluetooth adapter into the headphone jack. Then pair the adapter to the earbuds.
Yup.....supposed to work that way....but not for me.... I believe my BT transmitter is the problem.
My computer ONLY shows and connects when the BT Tx is on Rx (which I would think it's in BT receive mode).
I got it the BT Tx working after hitting some buttons......The Scoche manual SUKZ big time......there is a "Line" setting but the manual & user guide shows nothing about this.....really shows nothing useful to me....Then again many Scoche products I've had were the same way....gotta stop funding their junk....
Hopefully tomorrow with prime days that BT Tx you sent the link for will be on sale cause this one is not reliable unless I can find a useful manual!
Thanks to all for the help!
Ubbe
Stockholm, Sweden
Usually BT devices uses a battery save or sleep mode that are no problem in a phone conversation or listening to music but used with a scanner that can be silent for a while and then a short conversation are monitored it could have a switch on delay that makes you miss the first part of a conversation.
/Ubbe
2ahuman1791
Colorado Springs, Colorado
how do I get my SDS100 to transmit its audio on the 3.5mm jack to my Kenwood head unit audio in my car? I could just use my headphone port i installed in my car but the HUGE problem is when i charge the SDS100 from a usb port in my car it gives tons of RF static thats louder than the audio. I think i can solve this by changing my ground points from battery to car ground or vise versa but for now im trying to get my SDS100 to play its audio in my car so i can charge and listen at the same time.
