WB3DYE
Silent Key
I have a model number Bf-f8hp
I have successfully programmed some of the channels for amateur use. But Ive run into a goofy problem. I program the radio in the vfo and it works fine through local repeaters. But when I try to transfer from the VFO to memories the input for repeater becomes the output in the radio the output of the repeater becomes the input. In other words The frequencies are coming out backwards . I wonder if it’s operator error on my part or there’s a problem with the radio. Has anybody else experienced this ?.
The following link are the instructions
https://www.buytwowayradios.com/blo...rogram_the_baofeng_uv-5r_from_the_keypad.aspx
