Burlington County 700 MHz Project 25 TRS
rrpratt
Willingboro, NJ
Is there a map or chart available which shows the locations of the antennas/repeaters in the county? For the new system of course.
GTR8000
NY/NJ Database Guy
BEE00
Click on the FCC Callsigns link right above the site listings. That will show you all licensed sites for the entire system.
If you want to see the licensed sites for each cell, click on the site name, then click the little 1597768741586.png icon on the Site FCC Licenses line just above the listed call signs.
Keep in mind that those site maps are based purely on the FCC license data, so if that's not accurate or up to date, neither will the mapping be. We have no control over that, obviously.
rrpratt
Willingboro, NJ
If you want to see the licensed sites for each cell, click on the site name, then click the little View attachment 90102 icon on the Site FCC Licenses line just above the listed call signs.
Thanks. Just tried and the FCC side is down for mntnce.
GTR8000
NY/NJ Database Guy
BEE00
I wasn't able to navigate to what I wanted.
Did you follow my directions? It's all right there, as detailed.
jeff
St. Augustine, FL
Here's one from the 500 system. They're using those sites and have added sites in Evesham and Mt. Laurel which are not shown.
pfd461
Hello people, I have the new Burlington County emergency services proprammed into my sds 100 and it working pretty good, although I am in Burlington County. My question is I see all response talkgroups, but I didn't see any fire ground channels. I know they must have them. Any help on that matter and are you able to receive them county wide? Thanks for any info.
W2SJW
Senior Member
Northwest NJ
Firegrounds are 700MHz simplex (off the TRS). You have to be within 2.5 miles of the site to hear them (that's the range my friend in Medford got when doing portable-to-portable testing over flat ground).
pfd461
Thank you W2SJW. Yeah i kind of thought that was case, I guess I was just hoping.
Skypilot007
Medford, NJ
Terrain around here is thick with trees. I could barely here a fire ground channel when they were less than a mile from my house using a discone 40 ft up. You need to be close in to hear them. The 500 MHz fire ground channels definitely propagated better.
phillydjdan
Those 500 MHz simplex channels are not longer used. The reason the new 700 simplex channels aren't listed is they haven't been discovered yet by us.
GTR8000
NY/NJ Database Guy
BEE00
This is the list of the low power regional/nationwide 700 MHz frequencies available for use as on-scene/fireground channels. Note that analog is permitted on these frequencies, one of the rare exceptions in the 700 MHz band, so they may not be exclusively P25 (see Camden County).
769.00625
769.01875
769.03125
769.04375
769.05625
769.06875
774.93125
774.94375
774.95625
774.96875
774.98125
774.99375
joey123
nj
Is r1 still be ussed by medcom medicS dispatch have not Heard any activity for a while?????
tcfell
Burlington, NJ
For the Burlington County new system. Does anyone have the UIDs to program into the SD100 / SDS200? I started manually entering them. Be quicker if someone has a hard copy to just enter. Thank you
