rrpratt
Have to see if your SDS 100 pics it up.Maybe it's a different service type.
It does. But I have all the service types enabled. Easy fix. Press MENU > Scroll to SELECT SERVICE TYPES and Press the E button. Any service types listed as OFF change to ON by pressing E button as you scroll to them. When you're done press the SYSTEM key and see what happens.Have to see if your SDS 100 pics it up.
I'll check that out as I've seen this choices before. Guess I figured the Sentinel would cover that part.It does. But I have all the service types enabled. Easy fix. Press MENU > Scroll to SELECT SERVICE TYPES and Press the E button. Any service types listed as OFF change to ON by pressing E button as you scroll to them. When you're done press the SYSTEM key and see what happens.
It worked. Sometimes it's the simple things in life that get overlooked. Thanks.I'll check that out as I've seen this choices before. Guess I figured the Sentinel would cover that part.
Gonna take a wild guess that it's a patch setup for a call between units from both counties?Can anyone explain why Camden County is periodically on R5 like they are presently?
Interop channels/talkgroups allow different types of agencies to operate on a common resource, i.e. an operation such as SAR requiring agencies to coordinate with each other directly. Generally speaking, the Interop resources are not intended for routine day to day operations, but are instead reserved for incidents requiring a certain level of multi-agency/multi-jurisdictional response.I can understand that, but what is the purpose then of the Interop channels?
If any BurlCo units go to CamCo, R-5 is patched to whatever channel CamCo is using. Just liked when it used to be on R-4 of whatever zone it was on the old system, so CamCo doesn’t hear the rest of our general chatter.Can anyone explain why Camden County is periodically on R5 like they are presently?
That's pretty cool you here that way down there. They won't stop that because all the pagers require it. I'd just like to also get it on the assigned TGID as well.I) have to go on record I REALLY hope they never stop dispatching on 154.2200 because they;re bannging into Cape May tonight.. Love hearing just the dispatch
I just think the radio guys need to get together and balance the audio between the two county systems patched.If any BurlCo units go to CamCo, R-5 is patched to whatever channel CamCo is using. Just liked when it used to be on R-4 of whatever zone it was on the old system, so CamCo doesn’t hear the rest of our general chatter.
Imagine that, you can hear it in Cape May but we can't hear it in Cinnaminson-Delran-Palmyra-Moorestown etc. 😒I) have to go on record I REALLY hope they never stop dispatching on 154.2200 because they;re bannging into Cape May tonight.. Love hearing just the dispatch
