kg6nlw
Railroad & Ham Radio Extrodinare
It could be, but the likelihood of CDF being on the system already seems odd.What it be Felton calfire ECC?
Regards,
-Frank C.
It does make sense site 20 on Loma. Felton is located near Loma hills where CZU Calfire ECC isIt could be, but the likelihood of CDF being on the system already seems odd.
Regards,
-Frank C.
Seconded. They wouldn't change things up like that...Must've been something else based out of FELton.I'd expect CalFire to stick with their standard naming convention and use CZU in the channel names, like they do on VHF.
I'd vote for either the name being misunderstood, or it indicating something other than the CZU unit.
Seconded. They wouldn't change things up like that...Must've been something else based out of FELton.![]()
While it may or may not be CDF, it absolutely indicates that someone has radios programmed on the system already, perhaps an OES rig at a local (FEL?) station??It could be, but the likelihood of CDF being on the system already seems odd.
Regards,
-Frank C.
This is unrelated to CRIS, this is CalFire doing the 2021 radio load reprogramming statewide. Nothing CRIS in the 2021 load.Of note, I have heard several CDF units (mostly talking to Grass Valley) advising that they are going out of service for radio programming this morning.
I found a news story out of Santa Cruz and near the bottom the Felton Fire Chief talks about joining a "new statewide system". So looks like Santa Cruz County is coming on board. The 4502 encrypted must be SC Sheriff and this 4501 could be fire or sheriff.
Outdated ‘Flintstone’ radio system sounds alarm for Santa Cruz-area fire officials, sparks push for overhaul
SPECIAL REPORT: “The best way I can say (it) is you’ve got a computer from 1990 that has limited memory, and you’re trying to load the latest version of Google Maps,” Santa Cruz Fire Chief Jason Hajduk says of the system. But finding the money to fix things won’t be easy.lookout.co
Found TG22 with RID58 at 1158 on 6/3/21 on Mt. Saint Helena. Looks like just a channel grant, but still there...I've logged channel grants for TGIDs: 22 131 132 135 137 138 143 146 147 148 301 438 861 862 1601 3851 4502 50001
I'm reading that they have several issues. One is certainly coverage. Another is being able to communicate from inside buildings. There's more.... I don't see a "one size fits all" solution. SC needs to operate as both an urban and a rural county. Since their population has gone up, it seems they need to increase what they spend on radio solutions.They've talked about it. They are currently on VHF analog and it works pretty well. They do have some coverage issues, but a lot of it is because they don't want to invest in the system to address it. ...
Site 25 on the air. Pretty strong here... Coverage in Santa Paula/Fillmore would indicate South. Easy test.
I did some testing of this using a calibrated signal strength meter tied to GPS... I can conclusively say that this new CRIS site is South Mountain. Should be in the same building as CMARS Green.
But the idea of them switching to CRIS doesn't make a lot of sense. The Loma Prieta site doesn't cover enough of the county to be useful. 700MHz doesn't work as well as VHF in the mountains and the heavy forest.
Santa Cruz County currently has around 22 radio sites to get what coverage they do have on VHF.
Wanna guess how many CRIS sites they'll need to duplicate the coverage they have on VHF right now? Hint: It's way more than 22. The state isn't going to give those to them for free. They'll also need to buy all new radios.
Financially it makes more sense to fix the coverage issues they have on VHF than try to build out a new 700MHz system.
Cal Fire has interoperability with everyone in wildland fire. VHF-High is the band of choice for wildland fire and most natural resource/land management agencies in California and most other states, at least western states. ….. It isn't broken, so don't fix it.
I think if CDF wanted to switch to 700/800 it would be a disaster in many different ways.
Not that difficult to cross-patch VHF to UHF or 7/800 at the mountain tops...So yeah, they could have VHF easily.I agree with a lot of what's being said about VHF, 700/800 isn't for everyone, in portions of California it probably isn't for many.
Nothing says CRIS can't have VHF sites, of course that has difficulties involved as well.
If they are all running P25, I haven't seen a solution that makes the analog<->P25 transition sound good yet, some of them are getting better but still not great.Not that difficult to cross-patch VHF to UHF or 7/800 at the mountain tops...So yeah, they could have VHF easily.
Regards,
-Frank C.
