BC125AT: Charging my BC125AT with my Mophie?
dadonatrain
Clemson, SC
I’m so new I don’t even have my BC125AT yet! It’s due to arrive tomorrow just in time for my road trip to railfan in Ohio next week. So I’m still just RTFM-ing.
When I’m on the road I always have a Mophie or equivalent to charge my iPhone and iPad if I don’t have 120vac handy. Would it be possible and would it make sense for me to railfan out in the middle of nowhere with the Mophie plugged into the BC125AT?
RandyKuff
Lorain, Ohio
Sure, you can run your 125 from the Mophie... It will power the scanner fine...
If your going to use NiMh batt's in the scanner make sure the the switch is in the correct position in the battery compartment to charge them...
Also, the 125's internal batt's will only charge when the scanner is powered off and your Mophie is connected to it, or other USB power source...
n1chu
Farmington, Connecticut
While external packs are getting to a point where carrying them around isn’t cumbersome, they are probably still larger than if you carry spare AA batteries. It’s a personal preference. I’ve tried both and prefer carrying AA spare batteries. I ordered up 4 lithium-ion rechargable batteries, charger included from Amazon. They are called TENAVOLTS 2775mWh. I was curious if they would supply the same length of service as the Everready Lithium-ion disposable batteries (I don’t know how they are rated in mWh) which can be expensive. My results satisfy me, giving me a respectable length of usage before a recharge is necessary-I just haven’t done a scientific time study where I can say they do last as long, or not quite as long, or only half as long, etc. because everyone uses their radios differently and battery consumption will vary from one person to another and from one type of battery to another. (There are 3 rechargeable AA batteries I am familiar with; nickle-cadmium, nickle-metalhydride, and Lithium-Ion. I’m not sure if a Mophie has what’s needed to run the radio as it’s only designed to replenish the charge in a cell phone… it can do that at a lower current drain than the radio may need to run, so the Mophie’s design may be less than what is needed to power the radio. You might try it. It’s doubtful any damage would occur by trying the Mophie… it think the radio would either power up or not.
RandyKuff
Lorain, Ohio
An Iphone and Ipad draw way more charging current than the 125 will running...
The size of his Mophie power bank will determine how long he can run the 125 from it and/or use it to charge the AA NiMh's in the scanner...
vagrant
ker-muhj-uhn
California
I set the switch to Alkaline in my BC125 and never change it. I use rechargeable batteries, but most of the time I use an external USB battery plugged into the side port to power the scanner.
RandyKuff
Lorain, Ohio
Yep...
He said in his other post he's not going to charge in the scanner... That's the way to go... (y)
donc13
Grand Junction, CO
Setting the switch to Alkaline simply turns off charging. You can have rechargeable batteries in it, but the radio won't try to charge the batteries.
evilbrad
My head makes a bad antenna
Usb battery packs work awesome on USB powered scanners I left one on for few hrs forgot about it and it was still running. Which I wonder had anyone used a USB pack on a sds100?
RandyKuff
Lorain, Ohio
I use one on my SDS100 alot... It's around an 800ma draw on the powerbank...
hiegtx
Dallas, TX
I have a 30,000 USB Battery pack that has run my SDS100 for 24 Hours before.
I also use a high capacity brick, especially when I am on the road out of town, & trying to capture activity on a fairly new system. The 12v jack on my vehicle is only hot with the key on. Using the power pack instead makes sure that I don't lose activity when the battery (with the scanner plugged into the12v jack) runs down & the scanner shuts off.
evilbrad
buddrousa
I have a 10,000 as a backup for the 30,000. I would not buy a frontline less than 20,000 NAME BRAND.
The 30,000 I found in a bargain store for $10 never found another one for that price it was new in the box and sealed.
