mciupa
Canadian DB Admin
Moderator
I'm here a lot
But, is it a Phase II capable system?
If it is capable, then we list it as P25 Phase II even if no such talkgroups are on line.
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
I would wager that almost all P25 systems deployed today are "capable" of Phase II. It's going to be like phones manufactured after a certain point are capable of 5G (or LTE, or etc).
smason
Alberta Canada, Eh!
Here's a sorta-related question. For users on both systems (CFD for example currently dispatch on AFRRCS, TAC on muni) is it the same radio or 2 radios?
Same with antennas. For transmitting, there's a fair difference between 770 MHz, and 868 MHz.
So far, the Transit and a few other TG's seem to track with the Muni Motorola TGs divided by 16.
Have submitted this to the DB.
Sorry, I can't seem to get the text formatted properly here.
Decimal Mode Description Tag Category
600 D Channel 1 Bus 1 Transportation Calgary Transit
602 D Channel 3 Bus 3 Transportation Calgary Transit
605 D Channel 6 Transportation Calgary Transit
607 D Bus Dispatch Transportation Calgary Transit
612 D LRT 1 Red Line RTC Transportation Calgary Transit
613 D LRT 2 Blue Line RTC Transportation Calgary Transit
619 D Transit Ops 1 Transportation Calgary Transit
621 D Protective Services Dispatch Law Dispatch Calgary Transit Public Safety and Enforcement Section
650 D Law Department Security Operations Ch 1 Security Corporate Security Division
3007 D CPS All Call Law Dispatch Police Regular Service
Site 019 seems to be missing, Sites 13 15 and 16 are missing a freq unless you know something we don't :)
Jay911
Here's a sorta-related question. For users on both systems (CFD for example currently dispatch on AFRRCS, TAC on muni) is it the same radio or 2 radios.
Same with antennas. For transmitting, there's a fair difference between 770Mhz, and 868Mhz.
Most radios that can do 700 can do 800 as well, on the same antenna. My pro radio for Redwood Meadows FD, a JVCKenwood NX5000, handles everything from 763 to 870. I have AFRRCS as well as the "national" 700 and 800 interop simplex channels onboard.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
We should be good now:
RFSSSiteNameFreqs
1 (1)011 (B)Site 11866.5375c866.6875866.8375866.9625867.0375c867.1875867.2625867.3375
867.4625867.8375868.0375868.1875868.3375868.6875868.8375
1 (1)012 (C)Site 12866.4625866.6125c866.9625867.1125c867.7625867.9625868.1125868.6125
868.7625
1 (1)013 (D)Site 13866.5625c867.5625c
1 (1)014 (E)Site 14866.6375c867.1375c
1 (1)015 (F)Site 15866.7375c867.7375c
1 (1)016 (10)Site 16866.3125c866.8125c
1 (1)018 (12)Site 18866.4875c867.1625c
1 (1)019 (13)Site 19852.3875c852.5626c
smason
Alberta Canada, Eh!
So they’re using AFRRCS until the upgrade is complete? I’ve heard from sources that CPS has switched to AFRRCS permanently, they believe CFD is the same.
IMHO it would be nice to have CFD stay on AFRRCS. For me, in my location, it's a lot easier to hear. Even at the same sites that I can't really hear on Muni (Banker's for example) come in just fine on AFRRCS.
smason
Alberta Canada, Eh!
I submitted a few more confirmed TGs.
2 that don't seem to correspond to existing TGs in the Motorola system:
660 Transit - mentioned buses
4013 - unknown. Mentioned near airport.
StampedeCityStringer
Photojournalist
Calgary, AB
I would assume they are using the existing CMRN towers for this system. I'm picking up all but sites 13/14 and I'm in Huntington just off 14 St & 64 Ave NW. The new system seems pretty powerful.
I've picked up a couple more TG's that haven't been listed yet since I programmed this new system into my 996P2, both sounded like transit.
smason
Alberta Canada, Eh!
I'm getting 11,12,14,15 and 18 in McKenzie lake. 12, 14, 18 are full scale 11 is half, 15 is weak.
Photojournalist
Calgary, AB
Picked up a few new ID's. Multiplied them by 16, most seem to add up to TG's in the old system.
ID 3231 - Unknown, encrypted (no TG in old system)
ID 3129 - Unknown, encrypted (no TG in old system)
ID 2089 - CPS, encrypted (Old system TG 33424, CPS C7 Special)
ID 1115 - AHS South Health (Old system TG 17840, maintenance)
ID 649 - Transit? Maintenance related chatter. (no TG in old system)
ID 635 - Unknown (no TG in old system)
ID 634 - Unknown (Old system TG 10144, CMRN 10144)
ID 633 - Transit PS (Old system TG 10128, PS CPIC)
ID 629 - Transit (Old system TG 10064, SprngGdnsDsl)
ID 603 - Transit (Old system TG 9648, CT Ch 4)
ID 601 - Transit (Old system TG 9616, CT Ch 1)
Photojournalist
Calgary, AB
For the life of me, I haven't been able to get DSD+ or Unitrunker going. Been logging IDs with FreeScan for now. Looks like almost everyone but CFD is using this new system so far.
smason
Alberta Canada, Eh!
I have Unitrunker and DSD working at home on my Airpspy. For some reason, my work computer's Unitrunker no longer sees any of my RTL sticks. DSD works ok though. Very limited antenna there, but it does pick up a couple of sites.
Funny when I first started doing some searches last week, I had seen the new P25 system but because the freqs were the same as the Motorola sites, I ignored them. I should have clued in that they were P25 not Motorola when it said that right beside RSSI.
Jay911
The last time that happened to me, my machine had performed a Windows Update and Windows had annihilated the drivers that zadig had put in for my RTL sticks. Try running zadig again.
smason
Alberta Canada, Eh!
Good idea, but have already done. I did use a newer Zadig. An older one might work. Seems there was something (on Reddit maybe) talking about having to change the default serial number. Will fight with it another time.
smason
Alberta Canada, Eh!
With a fresh coffee and a slightly fresher brain, and some searching in the Google Unitrunker group, I re-ran Zadig with ignore hubs or composite devices off. It found the parent device RTL2838UHIDIR instead of the bulk-in devices, and I applied the driver to it. Works fine now.
