KB2GOM
Suggestions?
User reports?
User reports?
Hey there, I have been using a ZeroFive Ground Plane antenna for about 8-9 years now. Its built like a tank and NO radials !!!! 10-40 meters. I have it on a mast 10 feet of the ground with no problems. Works fantastic! I have my DXCC and WAS on several bands and modes. Is it as good as a beam, no. But it really gets out. If i can hear it I can work it. Customer service is GREAT !Suggestions?
User reports?
What are you restrictions? Installed on a mast/tower/roof or ground mounted?
Greyline Industries has a good vertical, you can get a flagpole version or just a plain version, this is a 25-30' ground mounted vertical, no ground radials.
I know some that have the Commet CHA250B and have good reports on HF on their micro-stamp sized lots.
Probably mounted on the railing of my deck.
I've had my CHA250B for 5yrs now and talked to hams in Germany, Russia, Spain, Austria, Nigeria, Slovenia, and Italy on 17/20mtrs with less than 100w out. It's also mounted about 15ft above the ground on my deck.The CHA250B is probably the ticket you are looking for, as I know one of the gentlemen have theirs mounted to their deck rail. It's not small at 24 feet, but it does 6m through 80m reasonably if you require a vertical. Not sure who has it in stock, DX is showing it will be in stock soon. I had one on order last year when things were backordered and ended up with an End Fed Half Wave that I am very happy with instead.
Roger that.Be careful with whom you deal with
I'll have to think about some others I've tested to see if anything stands out as acceptable performance.
End fed halfwave wire fed with proper matching transformer / balun as you describe run from the highest point on the pine trees at the north property line to a short mast gable-mount on southern most peak of roof. Run the feed line from gable mount down into your shack. This configuration has two advantages: 1) Greatest distance from power lines, 2) shortest run of coax. How high are the highest trees on north side of property? Use an AirBoss or similar device to cast the line for the far end of the EFHW into the highest point of the trees. This will give you a "sloper" installation of the EFHW, which is perfectly legitimate. The EFHW will work so well in comparison to a "no ground radials" vertical that you'll wonder why you spent the time and money to put a vertical on the deck railing.
1. If you use a commercially available EFHW from, say MyAntennas (there are others), then they come in two configurations: The EFHW 4010 which is 63 feet long and covers 40 thru 10 Meters EFHW-4010 and the EFHW 8010 which is 130 feet long and covers 80 thru 10 Meters EFHW-8010 I'm thinking you don't have enough space for the EFHW 8010 but you can make that call.
2. Both of the antennas above are complete with the necessary hardware and 56:1 baluns. They are ruggedized for outdoor mounting.
3. Many eave mount / gable mounts exist out there. Here is one Solid Signal 45"-60" Wide Adjustable Eave Mount for Antenna Mast (SKY32810)
Drop a short TV antenna mast (5 foot) in the mount that will hold the EFHW transformer hardware. Run your ground straight down from the eave mount, and the coax into the shack.
That was your previous class, but it doesn’t exist anymore. You’re a tech at the moment. Go get your general! It’s easyI'm a tech-plus, if that still exists
