County of Renfrew Digital Systems
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Nice sleuthin' :D
422.35 looks like Site 41 from OnQue
460.075 and 460.625 looks like a new site for PushPlus Network
The other two (VHF's) were listed by you as Turris Communications
IdleMonitor
Is this good enough info now to have submitted to the RR Database? All we need now is some talkgroups to go along with the info?
And yes, those others are listed as Turris.
Nice sleuthin' :D
IdleMonitor
I seriously got excited the first time I had actually heard a digital voice communication on the 460.075/460.625 frequencies. Not sure how I did it, but I heard it ;)
Nice sleuthin' :D
mciupa
Canadian DB Admin
Moderator
I'm here a lot
IdleMonitor
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Are we able to put 167.835 in with 163.755 and 159.090 with 160.080 seeing as they match with them as well?
Also the UHF PushPlush Network and the OnQue network. Are we able to update those now also?
You know I can only do that with confirmation, such as you provided with site numbers and neighbour lists.
I'm sure that will happen soon. :wink:
IdleMonitor
Is that not already confirmed in the earlier post? Especially with the OnQue network post
422.350 ---
2016/11/07 18:38:57 Current site: R202-41
2016/11/07 18:39:00 R202-41 neighbor: Site R202-21; CC=220
2016/11/07 18:39:00 R202-41 neighbor: Site R202-22; CC=122
2016/11/07 18:39:00 R202-41 neighbor: Site R202-23; CC=127
2016/11/07 18:39:00 R202-41 neighbor: Site R202-24; CC=128
2016/11/07 18:39:00 R202-41 neighbor: Site R202-32; CC=308
2016/11/07 18:39:00 R202-41 neighbor: Site R202-43; CC=200
2016/11/07 18:39:00 R202-41 neighbor: Site R202-44; CC=320
2016/11/07 18:39:00 R202-41 neighbor: Site R202-45; CC=321
And yes, I will continue to try and get more info on the systems that I managed to confirm as well. This has been something that I should've been able to provide a long time ago ;)
IdleMonitor
Here's a few more from the region. Was able to pick these up this morning while in the area, but I have no way of getting the information for them though.
163.440 - 7K60FXEXT - 2-slot DMR (Motorola MOTOTRBO) TDMA - Chalk River - Turris Communications Ltd. - Call Sign - VGS304
164.880 - 7K60FXEXT - 2-slot DMR (Motorola MOTOTRBO) TDMA - Chalk River - Turris Communications Ltd. - Call Sign - VGS304
423.850 - 7K60FXEXT - 2-slot DMR (Motorola MOTOTRBO) TDMA - Pembroke - Turris Communications Ltd. - Call Sign - CKH345
424.100 - 7K60FXEXT - 2-slot DMR (Motorola MOTOTRBO) TDMA - Pembroke - Turris Communications Ltd. - Call Sign - CKH345
DaveH
Ottawa, Ont.
Not only that, but if you get DMR activity on both timeslots at the same time on the same frequency, you'll hear both, one in each audio channel.
As for Network ID 201, VHF network has site numbers which duplicate some in the UHF network, not sure how that works, and how the DB will handle it...
Dave
DaveH
Ottawa, Ont.
Also, not quite sure about the dongle you're using but the RTL2832 has a cheap oscillator which almost always needs be corrected unless it is within a few PPM of the actual frequency. One I used was off by 57 PPM at room temp. Also, they are not terribly temperature stable. I know someone receiving VHF weather broadcast and if the temperature dropped 5C, reception got very messed up.
Also, may want try adjusting RF gain. Too low and you won't hear much, too high and there's a lot of compression and intermodulation crap possibly.
Dave
Dave
IdleMonitor
Yup, I believe that actually happened with the first comm's that I heard. I guess in the software I can ask it to listen to either Slot 1 or Slot 2 or both at the same time.
As far as the VHF network is concerned, I have a suspicion that this is what will be used by the County Public Works once it transitions over to it. If it hasn't already done so. I haven't heard them on there regular frequencies in quite some time now.
Here's the links to the maps.
Renfrew Connect Plus VHF Network
http://cdn2.hubspot.net/hubfs/35833... Connect Plus VHF Network.pdf?t=1478179723518
Eastern Ontario PushPlus Network
http://cdn2.hubspot.net/hubfs/35833...ntario and Western Quebec.pdf?t=1478110919857
Dave
mmisk
Ottawa Canada
A very busy site for you to try.
Try this frequency: 460.7875
It is presently the control channel for a very busy site.
This will give you an idea of just how much switching and activity there can be.
The other frequencies for this system are:
;C&W 201-3 (BUSY) Chateau Royale 1380 Prince of Wales 312188 Airport OPS,
; 309522 NRC, 312134 Security, 2503-1108 Security, 313703 Security, 308339 Security
Con+, 201, 3, 1, 461.58750, 0.0, 0 58
Con+, 201, 3, 3, 460.78750, 0.0, 0 59
Con+, 201, 3, 5, 451.68750, 0.0, 0 60
Con+, 201, 3, 7, 451.52500, 0.0, 0 NEW
The next step is to get you set up for listening to all the activity with DSD Plus.
Mike
IdleMonitor
If that is in Ottawa, then I'm not gonna get it out my way.
And I am using DSD plus.
Mike
IdleMonitor
Dave
Dave
I usually have to set my ppm to +28 which is not bad.
The rf gain I've adjusted fine. Weird though is I can hear one of the KHR Nexedge control channels fine on the scanner but yet can't seem to pull it in ok with the dongle to decode the signal.
