I tried to change a favorites list and that happened I don't know why please help
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #1 I tried to change a favorites list and that happened I don't know why please help
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,449 Location Gettysburg, PA & Fenwick Island, DE Jan 7, 2024 #2 try reconstruct database from the menu in Sentinel.
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #3 Forgot to mention I just updated the database
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #4 jtwalker said: try reconstruct database from the menu in Sentinel. Click to expand... ok then what
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,449 Location Gettysburg, PA & Fenwick Island, DE Jan 7, 2024 #5 Do whatever you were going to do.
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #6 jtwalker said: Do whatever you were going to do. Click to expand... it still gives me the error
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,449 Location Gettysburg, PA & Fenwick Island, DE Jan 7, 2024 #7 Someone will probably chime in to suggest what file(s) to delete manually then download database again. Did you interrupt the download process?
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #8 yeah I think I did I tried looking for the missing file on the SDS file system but could not find it
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #9 jtwalker said: Someone will probably chime in to suggest what file(s) to delete manually then download database again. Did you interrupt the download process? Click to expand... Can I take out the scanner from my pc while I wait?
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,449 Location Gettysburg, PA & Fenwick Island, DE Jan 7, 2024 #10 You didn’t get to the point of writing to the scanner, right? If so, should be fine to unplug and use.
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #11 jtwalker said: You didn’t get to the point of writing to the scanner, right? If so, should be fine to unplug and use. Click to expand... It did not write anything to the scanner it just gave me the error and stopped the process
jtwalker Member Premium Subscriber Joined Dec 3, 2012 Messages 2,449 Location Gettysburg, PA & Fenwick Island, DE Jan 7, 2024 #12 Yeah, unplug and use.
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #13 jtwalker said: Yeah, unplug and use. Click to expand... it booted up and said there was an error and to clear user data doing that now
SA_tx_88116 Rather listen than stream Joined Apr 2, 2023 Messages 466 Location Cibolo, Texas Jan 7, 2024 #14 That fixed the database and i was able to write to scanner
