If you get LNK it usually means that it cannot properly decode the datastream on the voice channel. Maybe because of a too weak signal or interferencies. It could also be that some systems move radios to a voice channels to transmit large chunks of data but are probably not used that often in systems so the most probably cause are some sort of receive problem in the scanner.
/Ubbe
