DMR in NC
KG4KHQ
High Point NC
Picked up a CAP+ system licensed to Cone Health Hospital in Greensboro, NC. This is the information I pulled:
464.700 MHz TG 2; CC ?; CAP+
Seems to be a multi-site system with an application for another site and more frequencies pending: ULS License - Industrial/Business Pool, Trunked License - WQVQ701 - CONE HEALTH
Also got another CAP+ system, maybe used by International Home Furnishings? (ULS License - Industrial/Business Pool, Conventional License - KYT689 - INTERNATIONAL HOME FURNISHINGS CENTER INC):
463.425 MHz CC 1; CAP+
In addition to those, I confirmed and submitted:
462.1125 TG 1; CC 5; DMR -- FedEx Distribution Center
462.1875 TG 1; CC 1; DMR -- PTI Airport: Airline Ground Support
The one for PTI is United Airlines.
IcomIcR20
DMR Tier 3 control channel heard in Greensboro on 462.250. My Uniden shows the color code as 0. That might be the first Tier 3 signal I've heard in the Triad thus far.
I've noticed a large amount of DMR licensed in Guilford County and have heard quite a bit on the occasions I'm over there. There are numerous DMR systems, mainly CAP+, but also all the other flavors as well. Anyone over there should have a field day IDing stuff as quite a bit isn't in the database.
IcomIcR20
New CAP+ system used by International Home Furnishings in High Point, NC discovered the other day and has been submitted to the database. It has pretty decent range as I was hearing it inside a building in Kernersville.
System Name: International Home Furnishings Center
County: Guilford
System Type: DMR Motorola Capacity Plus Single Site (TRBO)
System Voice: DMR
FCC Callsign: KYT689
Site 1 / High Point / Guilford County:
LCN 1 - LSN 1 - 464.700 - CC 1
LCN 1 - LSN 2 - 464.700 - CC 1
LCN 2 - LSN 3 - 463.425 - CC 1
LCN 2 - LSN 4 - 463.425 - CC 1
LCN 3 - LSN 5 - 463.6125 - CC 1
LCN 3 - LSN 6 - 463.6125 - CC 1
Talkgroups:
TG 1 / T / Operations
TG 2 / T / Operations
TG 3 / T / Operations
Flyham
Purplexed
County: Guilford
System Voice: DMR
Talkgroups:
I didn't pull the license to see if it's permanent or temp. But if it's temporary then it might be (or might have been) related to the High Point Spring Furniture Market.
IcomIcR20
It is a permeant license and some of it's voice frequencies have been noted in the past in this thread IIRC. Apparently no one had mapped it out yet, or if they did it was not submitted to the database.
GMB951
Cumberland Co,NC
Yellow Dot Business being used for different things 464.550 C/C-8 single freq around Fort Bragg area.
Another i will try to ID is 451.8125 C/C-7 also being used a lot here
They both sound like they are being used for (Events)
GMB951
Cumberland Co,NC
Anything on 464.8625/CC-1 loud and clear local sound like maybe security calling central ref lost child in spring lake area
GMB951
Cumberland Co,NC
These come in loud and clear from Spring Lake/Cumberland Co
151.2700 or 275/CC-1
152.895/CC-3
451.050/CC-1
453.3375/CC-11
460.4375/CC-1
153.075/CC-1
155.8050/CC-1
GMB951
Cumberland Co,NC
Monitoring 154.2100 CC-1 calling centeral using locations in Sampson Co (Roseboro)
Maybe EMS ID-1 ???
Upon checking it appears Sampson Fire has switched over to DMR will get it sumitted
GMB951
Cumberland Co,NC
Don't know what going on here but have started monitoring a NC prison Ops Loud and clear on #463.4250 CC-13 could be conditions because I have monitored VA radio communications on UHF for the first time #451.0500 Nac#500
Are you sure it was NC prison comms you heard? According to a FCC license check NCDPS/DOP (or any other state agency or private prison/jail) does not hold a license for that frequency in North Carolina, however there is a radio rental license in the Charlotte area on that freq, and the NASCAR Hall of Fame licensed for DMR in Charlotte.
