DSDPlus DSD & P25 KEYID
AF1UD
One of the police departments in my area has turned on encryption. I got a RTL SDR to inspect the traffic and found that there is a keyid associated with each transmission. What is it and why does DSD give the output for it?
caphab1
Mesa, AZ
Figure this thread might give some answers for what you're looking for.
AF1UD
So... it's the challenge key for the radio with that ID to be authenticated?
caphab1
Mesa, AZ
So by my gathering, all radios on the network have a list of a certain number of keys programmed, the transmit radio picks one and broadcasts it to the rest in use so they decode the ENC transmission.
maus92
OCMD
The keys are stored in the radios. The KeyID is telling the radio what key to use.
AF1UD
So is it using key 4128 or keys 4, 1, 2 and 8?
Kazzaw
South East QLD, Australia
Using key 4128.
Basically, when someone transmit, the radio sends out a message saying ' We're using key 4128 for this conversation'. All the receiving units, providing they are programmed correctly will then use whatever key they have stored in 4128 to decode the transmission correctly
boatbod
Talbot Co, MD
To the OP: there's a Message Indicator parameter too. That's used along with the KeyId to select the correct encoding type and seed the crypt algo.
AF1UD
Are you referring to this?
dlwtrunked
It is the number of the key but not the key itself. Note that the number can be randomly picked by the system programmer and they do not need to be assigned sequentionally or in order. Note also that Al=AES means they are using AES encryption (as opposed to something like DES encryption). Sometime on a large system, it helps you understand the system as it can indicated what talkgroups or units can talk to others. In other cases, it might help figuring out is different frequencies are the same operation (but of course different operations may use the same key number just by chance).
SlipNutz15
Wacker
Central PA
How are you displaying that info? I'm trying to view the same info, it's decoding the system, but that information is not showing.
SlipNutz15
Wacker
Central PA
I dont think there are any specific settings, it should just appear when an encrypted group appears
For some reason when monitoring our system in PA it says encrypted TG, the TG number and unit number but not keys
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
It's a feature in the new(est) versions of DSD+ Fast Lane, I'd say about the last 5 versions so you have to be pretty much up to date.
I believe your role has to be 1R (combined CC/VC) and you have to enable "Limited Encrypted Conversation Following".
I have my DSD machine apart right now or else I'd get you more accurate info, sorry.
SlipNutz15
Wacker
Central PA
Yeah I downloaded the latest and updated my folder and it shows it’s an encrypted convo but no key data.
cg
Connecticut
it is in the Fast Lane version.
In a trunked system, you need to allow the secure group to be monitored as the key info is apparently read from the voice channel.
