DSDPlus 2.296 FL
grantbob
using the new update 2.296 with FMPP using an RSP1A the LNA gain now only goes to 3 now, it use to go to 8 or 9, I cant even pick up a somewhat local p25 that was has a very high signal????????
I'm seeing the same behavior with the RSPdx. I switched back to the previous version for now. The new release only seems to mention the RSP1a and not what to do if you have one of the other RSP's which was previously working.
KMG54
Easley S.C.
I just updated and now windows says it can't run 1R bat. FMP24cc works, but tried admin mode and still says Windows can not run the R1 batch file. Anyone run into this yet? Looks like I need to start over, copied my original Bat1R to the folder, but still won't run.
KMG54
Easley S.C.
Blue box that says windows can not run this app. No error code.
KMG54
Easley S.C.
I am between a rock and a hard space, Love DSD+fastlane, but hate windows, love Linux, but hate OP25. lol
mwjones
Van Alstyne, TX
If its the pop up that I think it is, click on "More Info", and then it will give you an option to "Run Anyway". Once you do that, it shouldn't ask for further launches (until you upgrade again).
KMG54
Easley S.C.
And the winner is: Slicewizard! Sure enough empty file. I used 7zip and my password worked and all looked fine. Never thought to check the Exe. file. Ran 7zip again and all is working now. Thanks guy's.
Vermonster
north of the 45, NH
Just validating those experiencing crashes. It ran for several days on this same system (Con+ site) without issue, but now crashes every few hours.
Error
CC DSD+ 2.296
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x408349
Thread = #1
Action: Write to address 0x3F3F41 (4144961)
Register dump:
DS: 0000002B CS: 00000023 IP: 00408349 EAX: 00000004
ES: 0000002B SS: 0000002B SP: 0019CD20 EBX: 0019D73C
FS: 00000053 Fl: 00010206 EBP: 0019D1A0 ECX: 0000003F
GS: 0000002B ESI: 0049C5B4 EDI: 0019D678 EDX: 003F3F41
Press Ctrl-C to copy this text to the clipboard
OK
IU0LFT
Italy
My one is working without problems, but I'm using SDR Console and SDR-Sharp, instead FMPxx
kanila
Oakville, ON
have SDRPlay and when i set it on a controll channel, after a couple of seconds it jump off to 0.0125MHz higher and sits there. This is using FMPP-CC bat.
This is on CC/VC and regardless of the network i set it on. It is not a ppm deviation, because if i use it with SDRUno for example, the frequency is correct - checked with the clock frequencies on HF.
If I swap the SDRPLay for RTL-SDR v3.0 and run the FMP-24, it all runs well.
slicerwizard
Toronto, Ontario
DSD+ thinks the control channel frequency is 857.2625 and that's where it's telling FMPP to tune to.
Edit:
You're monitoring Halton south zone and 857.2625 is the correct control channel frequency, so it looks like your SDRPlay is off frequency. Not sure what options you have to fix that.
You could try bumping the channel bandwidth in FMPP up to its maximum; that might let it see the control channel and auto-correct the fine tuning, but that won't help with the voice channels. You'd have to try the same thing on each of them.
LimaZulu
Believe it or not IT IS actually PPM related. I had the same issue with RTL-SDR. It turns out that PPM correction that I set works just fine on VHF band and trunk tracks wonderfully. As soon as I jump to the same trunk system but on UHF band it does what you're experiencing. If I set the PPM to be "correct", UHF system is working nice but of course I'm loosing the VHF one. Had this issue since well, almost forever :) Never that big of a deal for me as I almost do not listen to the UHF system, so I keep the settings just right for the VHF one.
I was always thinking that the reason is the cheap chinese receivef.....well, maybe not :)
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Starting to see a lot of crashes here and some other weirdness with my SDRPlay RSP1a.
Maximum LNA gain seems to be set at 3. I believe I could go as high as 6 or 7 before.
Sometimes when starting, it seems to go into Combined CC/VC Monitor mode and starts looking for a control channel. Setting it to Passive Digital Monitor doesn't help as it continues to look for a control channel.
kanila
Oakville, ON
Any idea how to correct PPM on FMPP-CC? It does not accept a "-Px.x" parameter (which works for FMP-24).
LimaZulu
Nope, sorry. I use cheap chinese rtl-sdr and FMP24. How about pressing p/P when FMPP Is on focus?
