DSDPlus DSDPlus Fastlane Update V2.228 on 12/21/2019
radioopperator
It said put the sdr file they supplied in the FMP dir and I have them all in the same dir. With no luck with out TCP.
I ran sdrplay then started just the dsd2228 and it says machine refused TCP. I did not start fmp24.
SM5GXQ
That's exactly what was going on here, it was now defaulting to R1.
The other thing that threw me at first was it did not honor any of my screen positions saved in the dsdplus.bin file at each exit.
When I started this new version, it was like the first time it had ever ran and I had to redo all my screen sizes and positions which was no big deal.
I just found it odd that this occurred as it never had before. Probably something with the changes in the Event Log window.
Anyway, it's all good once again and discriminator audio is decoding just fine via line in.
Thanks All.
Hi,
I tried -rv and -rv but my DSDplus is still defaulting to tcp Connection.
rgds
Peter
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Do either:
a. use FMPP + DSDPlus
OR
b. run the software you prefer that controls SDRPlay and then pipe the audio to DSDPlus (no TCP linking).
The latest version of DSDPlus defaults to a configuration where it presumes you are going to be doing TCP Linking ( FMP24+DSDPlus, FMPA+DSDPlus or FMPP+DSDPlus). If you aren't doing that, then you have to use the menu system in the EVent Log Window and go to Control and then select Passive Digital Monitor. Then you will go to Input and select your input source.
kd5dga
Killeen,Texas
I received my link sometime in the wee hours. DSD Plus Fast Lane is up and running as expected. I will have to tinker when I get home from work.
Thanks to the DSD Team. I did see some good changes.
dave3825
Suffolk County NY
Ahh, That was it.. Didn't see that mentioned in the notes..
Worked fine before..
My files were in all perfect condition, with commas and in the proper formats listed in top of the files. After loading up new fastlane, dsd reported many error in networks, freqs and site files. When I went in the files, many comma's were gone. I know they were there because I back up networks, sites, radio and group files every month and the commas are in the backups from last week.
mtindor
OH/WV DB Admin
Hi,
rgds
Peter
Read this whole thread. Follow the instructions (with screenshots) to enable Passive Digital Monitor so that you have access to the Inputs and select them.
1. Menu --> Control --> enable Passive Digital Monitor
2. Menu --> Inputs --> choose your input
Mike
air-scan
I have 2 months left on the dsdplus fastlane subscription. I hope they aren't shafting me out of them two months!
hullfreqs
Hull
Hello all
I wonder if anyone could help, i have been using fastlane for ages and never had any problems updated to 2.228 and now getting this message, I am in the uk so no p25 around me all i use dsd for is dmr nxdn, so have no interest in p25 anyway, all i do to decode is input out from my whistler trx 1 and when i try this new update it just shuts down after the message, if anyone could help i would be so thankful
Dale
DRL-XM43
Durham Region
Hi Dave, my bet is the bit grinch - it is that time of year and I hear he is loading up on comma's :)
Steve999
Just downloaded the latest fastlane version 2.228 and when I try to run DSD+ I get the following message. Never had it before, anyone have a simple fix?
Message is "DSDPlus.siteloader file not found in working folder"
mtindor
OH/WV DB Admin
Sounds like you have not downloaded / unarchived / overwritten older data with new data every time a new version came out. Otherwise I'm pretty sure you would have that file.
But, you can simply make a blank text file called DSDPlus.siteloader (make sure it doesn't save it with the txt extension) and put it in your DSDPlus folder.
Attached is a very basic DSDPlus.siteLoader file (with .txt on the end so that I was allowed to upload it).
1. no examples in it. But instructions are in it
2. rename DSDPlus.siteLoader.txt to DSDPlus.siteLoader
3. put it in your DSDPlus folder
NOTE: I ended up putting examples in it. For example:
P25, BEE00.348, 0, "MARCS-IP"
P25, BEE00.348, 2.63, "Stark County"
Basically, to create trunked system listings in the siteloader you first must make a network entry (that is the first line above). The network entry always has 0 as the site ID. Then you need to make a site entry for each site in the system (that you might want to monitor and can hear). The documentation at the top of the file is helpful.
mike
  • DSDPlus.siteLoader.txt
hullfreqs
Hull
is there anywhere i can download the DSDPlus.P25data file as i am doing somthing wrong and not have much luck please, i am not good with pcs anymore so all help is very needed
pro92b
Mutated Member
Anyone else having issues with the window size and location output? The values dont resemble what I have already setup in my .BAT files.
I have the same issue but haven't figured it out. What did you do to gain control of window size and position?
