DSDPlus2p523
dave3825
Suffolk County NY
If your trying to run DSDPlus out of a directory on your desktop, the adress should not be showing what its showing in your pics
Could you please figure out windows snip and provide pics of your DSDPlus directory? Something showing the location of the directory?
Could you look in your directory for this event file. Open it in notepad. Scroll to the bottom and look for these lines. Copy and paste in message. Be sure to remove your personal details on the line after DSD+/Fast Lane Release
1745333580023-png.182218
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
Your screenshot shows your DSD+ root directory but the DLL needs to reside here as I tried explaining to you in posts 2 & 5 for the app to launch successfully. Open DLL folder then select all DLLs contained within. Copy (don't cut) all DLLs from your DLL folder. Click back button to return to your DSD+ root directory then paste them there
dave3825
Suffolk County NY
I looked at both pics he posted and neither reflect the install he says he has on his desktop.
My dsdplus in on my desktop which gives me access to the files in the folder
The last pic shows he is trying to launch DSDPlus.exe out of the update folder as there are only 2 files in there,
And the last update was only 2 files.
United Kingdom
Have started all over again and still have the same problem. But here is the pic requested
morfis
We still need to see how you are starting DSD. In it's default state it shouldn't throw a terminal error even if the lame dll file is missing.
dave3825
Suffolk County NY
Your update files are not in the directory your launching DSDPlus from as it’s saying you on version 2.347.
You need to locate the update (DSDPlus2p523.zip) that should be in your DSDPLUS2 folder.
Unzip the update.. It should create a folder DSDPlus2p523 inside your DSDPLUS2 folder.
Go into that folder and copy DSDPlus.exe and Notes.txt
Then place them in you DSDPLUS2 folder.
dave3825
Suffolk County NY
Probably better to set up a date and time or have op leave pc running.
Let us know what you find.
