EBRCS Question Thread
Oakland_Tower
S.F. Bay Area
The outside antenna might be the problem. I have a 996 here in Fremont as well and its works fine using the telescopic antenna that screws into the radio. Keep the antenna lowered too to about 6 to 8 " . Also, check the squelch...might work better all the way off. You shouldn't have a delay.
worble7
Fremont, Ca
Not getting Fremont police/fire with a hp1
ok so here the deal I was getting the Fremont pd real good then put the newest hp1 firmware and now I get very little to none with a bunch of antenna's so I ordered a st2 antenna should get it this week and see if I get better reception for pd/fire tried loading old firmware files still cant get it working right now im thinking of getting the whistler 1080 can someone let me know what really going why i cant get my own city I live in seams strange to me . thanks for any and all help. Jeff
also I tried the weather and it works fine.
northzone
Northern California
This has been well discussed in other threads. Go back to firmware version 2.04 or earlier and the problem will be resolved.
whisper16
Fremont Fire
I just purchased a radio shack Pro 668, my first digital scanner. I would like to listen to Fremont Fire. I'm in south Milpitas. Will I be able to get reception from my location? Confirm that Fremont Fire is on the SW site? Which talk groups should I program?
Thank you!
Oakland_Tower
S.F. Bay Area
re Fremont Fire
Yes, you should hear Fremont Fire from Milpitas on the Alco SW cell. They are dispatched by Alameda County on Dispatch 1 (2605). Unfortunately, you will also hear fire/ems calls for Union City, Newark and Alameda on that same talk group. For working fires, they will be on Command 5 (2665) or Command 6 (2666).
whisper16
No reception
Oakland Tower thanks for your response. So far I have had no luck in getting reception. The signal bars bars bounce up and down, and the T flashes on and off. I have adjusted the DSP level and the threshold levels, but nothing seems to make a difference. I have tried both the stock rubber duck, a Watson W-801, and my rooftop DPD Omni X antennas.
What do you think the issue is?
rooivalk
EBRCS is a simulcast system. You may not be able to receive it, as a scanner isn't designed for it, regardless of what the scanner's specs may be.
I tried everything with EBRCS and two different radios, and have the same issue. What marginally worked, was a cheapie 1 inch long antenna (I can't read the brand, but it was advertised for NASCAR racing venues), and I still have only 50-60% reception reliability.
stingray327
San Francisco, California bay area
In Contra Costa County on the EBRCS system I am picking up on HP-2 scanner unidentified agencies.
One of them sound like a fire channel.
TGID 5002
UID 3284030
TGID 2606
UID 3013004
TGID 5554
UID 435032
Is there a way to identify these unknown channels and agencies?
It would help to include some specifics on the traffic you are hearing. Locations heard, which CCCO cell (West, Central, East) you are hearing this on...
5002 has been identified. See the database.
2606... same story... been identified, see the db.
5554... likely AMR, according to my notes.
Peter
Piedmont, CA
(Hopefully) Quick question: I live in Piedmont and have a BCD396T. Either I have not programmed it correctly, or I can no longer use it to pick up local PD and FD. Do I need to either:
1) Program it correctly with new frequencies
2) Get a new scanner, like the BCD436HP
3) Find a new hobby
Thanks for the help!
stingray327
No that's not the reason. Oakland hasn't been talking much if at all. They have not completely made the switch. Units have only been active for radio checks
I programmed about a year ago from the info on this website so that should be fine?
I should eventually pick up Oakland PD once they start to transmit?
It makes me wonder then what are they transmitting on currently?
cozmo
Germantown
3) Find a new hobby
Just re program it using the East Bay Regional Communications System (EBRCS) for Alameda County on the ALCO Northwest Simulcast site. All the info you will need is in the data base. Start with the freqs for the Northwest site. They are 700 MHz. Then scroll down and find the correct talk group's that you want.
Hope that helps.
Peter
Piedmont, CA
Hope that helps.
Hi,
That's what I had done, using FreeSCAN and the EBRCS data. But the only communications I seem to hear are for Berkeley PD. I can see that all the Talkgroups that I'm interested are loaded in the scanner, but I never hear anything from Piedmont. Do I need to make any other adjustments?
Thanks!
cozmo
Germantown
Hi,
Thanks!
Piedmont has not been too active lately. Might try switching to PFD when you hear their siren's and wait a few min and see if anything comes up.
I did hear PPD a few hours ago doing a car stop. They came in just fine during the short time I was listening.
kma371
I think Piedmont has 1 or 2 officers on duty and it's not a very large city. Activity is very minimal.
