Yep yep! Or, ideally, you have an air system that doesn’t leak. Air can replace electricity in many cases. I’ve run trucks with air windshield wipers, air horns, air actuators in place of solenoids for PTOs, tire inflation systems, air brakes and suspension, air chucks for tools… cool stuff.
Yep, the (now old) 2 1/2 ton trucks "duece and a halfs" had those, the windshield wipers were fun and needed manual assistance sometimes, although I think they were technically run off of the engine vacuum, with air brakes, the air tanks were recharged when the engine was running. There were actually military training roads that trucks with air brakes were not allowed on because its possible to run out of compressed air if not careful on a long downhill section.
Compressed air is an under-looked at possibility for energy storage without batteries. (A more common possibility is to pump water from the bottom of a hydro-electric dam to the top. The other less considered possibility is using large salt caverns to store compressed air.
On a very small scale a normal person could do it (kind of) by using an air compressor (that runs when more electricity is produced than used) to fill an air tank. When the stored energy is needed, an air drill connected to a small generator would provide some power. (none of this is sterribly practical, but it is an option).
Joel
