EVX Emergency Button Set-Up
Kf4mnc
OK Folks, I am about to pull my hair out . . . I am trying to set-up the Emergency button on some of my radios and I can't get past the following error. can someone please give me some guidance here!
On the Emergency Screen I set the channel I want to broadcast the emergency on and I get the following error message:
"On the Digital System, Select the CH that TX ID type of contact list set to "Group Call"
Any help is appreciated!
Kf4mnc
Update, after a lengthy phone call with tech support we were unable to get it to work. It was suggested that I change my programming, in a not so clear way, so I played with it this afternoon and got the emergency beacon to work. Basically, you can't have your #1 contact set as "All Call" AND you need atleast ONE contact set as a "Group" for it to work. I still have some other bugs to work out, but I am getting there. The one response the tech wouldn't/couldn't articulate to me was how you can have a Contact "Group", but there is no way to put individual contacts into that "Group" You have to use "RX Lists" and associate them with the "Group".
My new problem is, how do I get a radio that is a member of ALL groups to receive ALL transmissions regardless of the channel it is one? Right now it only receives them if it is on that particular channel OR it is set to scan every channel, but then that causes problems with the emergency button as it is automatically acknowledged and silenced. I don't understand why this wouldn't work since I can do a digital "All Call" and all radios here it regardless of the channel they are on.
