I'm using an SDS-200 & ProScan (v. 22.8) to send the local county fire/ems feed to Broadcastify. Every couple of nights (and yesterday at 17:46 which is unusual) my feed gets booted offline and has to reestablish it's connection. The log says "Error Code 10 - Unable to write data to the transport connection: An existing connection was forcibly closed by the remote host". And then after ProScan's built-in 10 second delay it reconnects to Broadcastify with no issues.
Any ideas on what is going on?
Per the FAQ page on the proscan.org web site
Q: I'm using the Source Client feature to stream audio to Broadcastify. I'm experiencing intermittent dropped connections.
A: Intermittent connections could be caused by your computer, NIC card, cables, router, ISP, far end, etc. It has been suggested by a few users to use a tool called
PingPlotter to isolate where the problem is.
Ensure you're not using AVG Anti-Virus software as that will interrupt TCP traffic.
If using the BCD536HP Wi-Fi, click the URL Audio Setup button and see if excessive Packet Loss shows in the dialog. Wi-Fi interference or a flaky Dongle could cause excessive packet loss. Move the dongle and scanner to another location to see if the packet loss decreases.
These links may be helpful.
BCD536HP WI-FI dropping issue
Feed keeps dropping out
Connection Issues
