External ham radio speaker for the chase vehicle
5stormchasers
MS
Here are a few pics of the install of the external speaker for my Yaesu 7900!
Before..
The joys of splicing wire!
Le's hide this wire under that step...
Speaker mounted under the vehicle!
Hooking up the switch!
Place the switch in a compartment, and we are done!
WD4JKH
Peach State
You wont have to worry about overloading the speaker.. ;)
Are those zip ties holding the speaker in place under the vehicle?
WB4CS
Northern Alabama
Question...
While storm spotting, what purpose does the loudspeaker serve? I'm racking my brain and can't figure out what exactly would it be used for.
5stormchasers
MS
Yes. I am using zip ties to hold it temporarily. I am in the process of making a bracket for it.
5stormchasers
MS
It will be used while I am outside the vehicle. I like to get out of the vehicle while storm spotting. From my vantage point I can see storms a long way out, so I get out of the vehicle to take pics. My speaker inside the vehicle isn't loud enough. This is a perfect solution.
WB4CS
Northern Alabama
Ah-ha, that makes sense :) I forget the rest of the country isn't like Alabama. There's so many hills and mountains here that it's best to stay inside the car while spotting, you never know when you'll have to get out of the way quickly!
Thanks.
lafd55
Albany, NY
Very bad that only zip ties(weak ones) are holding it in place..... Haven't you heard of a portable? Or a Bluetooth...
KB7MIB
Peoria, AZ.
Wirelessly posted (Opera/9.80 (BREW; Opera Mini/6.0.3/27.2338; U; en) Presto/2.8.119 320X240 LG VN530)
The zip ties are temporary. He's making a bracket for it.
johnoconnor98
Memphis
I don't know if that's the best speaker to use. It looks like a siren speaker/driver. If so it is probably 100w at 11 Ohm impedance. That might put too much of a load on the 2w, 8 Ohm audio amplifier in the radio. there are 8 Ohm outside speakers available for $10-$20.
mikegilbert
MHz so good
Los Angeles
Zip ties? Really?
Why even mount it before you finish the bracket? If that speaker falls off while driving, it could seriously injure a motorcycle rider or damage a vehicle behind you.
First the whackerish home made signs and flashing lights. Now you've got equipment mounted in a dangerous fashion.
You really need to think before installing.
WD4JKH
Peach State
Huh? An 11 ohm speaker will be less of a load than an 8 ohm speaker.
jim202
New Orleans region
When was the last time you tried using Ohm's Law?
The higher resistance will be less of a load than the 8 Ohm speaker.
By the way, has any thought been put into the location of the speaker being mounted under the vehicle? The location shown looks like it is under the vehicle. This is a fine place if you want to destroy the speaker with water from splashes while just plain driving in the rain. Why do you think most of the public safety external speakers are put under the hood or in the grill? This reduces the amount of water these speakers ingest. Even at that, the speakers need to be replaced with time and weather conditions. Salt just eats these speakers up.
WD4JKH
Peach State
That's what I'm saying. Your previous post was the one saying an 8 ohm speaker will be less of a load than the 11 ohm siren speaker.
BigLebowski
Piedmont NC
Would it not be easier and a lot more functional to just get a vehicle repeater?
I mean... unless the point is to be as loud as possible, a proper mobile radio for receiving whatever it is that you want to receive coupled with a vehicle repeater and a portable radio would probably be the best solution to the whole radio outside the car thing.
jim202
New Orleans region
Sorry, but you have it backwards. The lower impedance will cause more current to be pulled and as such more noise. I mean sound, on the output.
