XBrandonEdwardX
Telecommunications
Niagara Falls
Hey Everyone,
This was something that was brought to my attention last week, but I can now confirm that the Fallsview Casino Resort has switched to DMR Capacity Plus from their previous LTR system. They have also implemented Restricted Access to System (RAS) and is using both basic and enhanced encryption depending on the talkgroups.
Previously they used a mixture of Motorola HT-1250 LS+ and XPR-7550 radios. I am assuming that they finally made the switch because LTR has reached its end-of-life a while ago, and that Motorola no longer makes the LTR option board for the XPR series radios. Who knows, maybe they have some of those new fancy R7s?
Furthermore, I also see that some of their DMR radios are broadcasting OTA-Aliases. However, they seem to just be the DMR ID number associated to that unit. I have yet to see any Automatic Registration (ARS) or any kind of GPS (GNSS) location data coming through. I also have yet to pick up the frequency LCNs... I plan on doing that today.
Anyways... that's what I've picked up so far. I will update accordingly.System Info.png
VA3ADP
Mississauga, Ontario Canada
Hey Everyone,
Interesting find.
I think that if they are indeed using EP or BP they would be using one or the other. It is possible it could be a false decode?
XBrandonEdwardX
Telecommunications
Niagara Falls
Interesting find.
While anything is possible, I have observed BP appearing both from my residence and when parked on Robinson Street across from the casino recently. It has surfaced multiple times. Additionally, RAS intermittently appears — sometimes it is active, while other times it is not. This suggests that they may be utilizing the repeater in 'Migration Mode,' allowing transmissions to pass through regardless of whether RAS is programmed. However, I cannot confirm this with absolute certainty at this time and will need to conduct further monitoring of the system.
XBrandonEdwardX
Telecommunications
Niagara Falls
So, while waiting for my vehicle to be finished at the dealership, I have been sitting here watching my SDR and DSD+ to see if any additional information pops up about this new Capacity Plus system. Still utilizing encryption on all talkgroups, I have yet to see a "clear" transmission. Furthermore, I have decoded LCN 1 & 2, which will give their system 4 data/voice paths.
  • LCN #1&2: 422.5750
  • LCN #2&3: 422.6750
Note: the frequencies above are coming up as S1, CC6. This may be important in the near future, as I recalled seeing some DMR traffic on the Casino Niagara system too. I believe they have both updated... I will look into that system a little later on.
Unfortunately, I only caught 1 screenshot that shows 422.5750 as 1&2. I plan on watching the other 7 frequencies to see if I can pick up anymore LCNs. I also noticed that the "Fallsview Casino" trunked system has disappeared from the database. I think now we should have enough details to restore/update the system.
16b
Central Ohio
While I don’t have experience with the latest TRBO radios (R7, Ion,etc), all of the others only allow one encryption type to be active at a time. One of your screenshots shows both BP and EP on the same talkgroup (14); that’s almost certainly a false decode. My money is on EP being the real algorithm in use. I see a lot of false decodes indicating BP on DSD Plus. Most of the time it’s on an EP channel, but sometimes unencrypted as well.
exkalibur
York, Ontario
You cannot mix EP and BP in the same radio. AES will show up as EP so it is possible you're seeing a mix of AES and BP (which IS possible in the same radio).
XBrandonEdwardX
Telecommunications
Niagara Falls
@16b and @exkalibur, you are both correct on the way that encryption works. You cannot run Enhanced Privacy and Basic Privacy at the same time. However, you can run Enhanced Privacy and AES together. There's no indication of them using AES, though.
I didn't pay attention to the radios that were keying up with Enhanced Privacy vs the ones that were keying up with Basic. There is a possibility they were different units talking on different talkgroups. My main goal was to confirm what kind of system it was, and what the LCN's are.
At this time, I have only picked up Site-1 as the Fallsview Casino Resort, with 2 LCN's. No other frequencies are containing the Capacity Plus beacon that the radios require. I will also be looking into the Casino Niagara frequencies too, as I think they were on "Site-2."
As time goes on, and I have some more time to dedicate to this, I will be able to provide more details.
As of right now, I spent maybe about an hour watching the system tops.
XBrandonEdwardX
Telecommunications
Niagara Falls
Update:
I am no longer picking up analog LTR trunking data on any of the Casino Niagara (old casino) frequencies. However, I am picking up DMR Capacity Plus beacons on two of them. I have yet to decode any talkgroups or radio IDs, but I am pretty close to getting the frequencies and LCNs for that system. So far, I have decoded:
LCN #1&2: 422.56250
LCN #3&4: 422.76250
These frequencies are showing up as "Site 2" with "Color Code 7." I was able to finally hear some encryption noises coming from talkgroups 14 and 104. According to my DSD+, they are both using Basic Privacy (BP) encryption, however... there is a possibility these could be false decodes as per my last conversation with @16b...
I will have to try and scan this system a little closer to the building.
Checking back on my first set of screenshots that I posted, I can also see that it captured talkgroup 14 on "Site 1" using BP. I wonder if that's a linked talkgroup between the two properties?
I know for a fact that the two locations share security and maintenance personnel. I believe they share cleaners too, but they are a third-party contract.
Maybe we can change the database listing to "OLG Casinos," and change the type to a multi-site capacity plus system? Maybe "Site 1" can be renamed to "Fallsview Casino" and "Site 2" can be named "Casino Niagara?"
CONFIRMED THIS IS A LINKED CAPACITY PLUS (LCP) SYSTEM!
(See the attached screenshot)
XBrandonEdwardX
Telecommunications
Niagara Falls
Update:
Over the past 30 minutes, this is the information that my SDR has picked up. I am going to leave it scanning throughout the night to see what happens.
Talkgroup IDRadio ID RangeActive Users
146xx & 7xx3
228xx6
294xx2
Judging from previous experience listening to their LTR system, I feel confident in saying that "22" is probably the machine technicians. I haven't been able to determine talkgroup "14" or "29" yet. Though, I have a strong feeling that "14" is a linked talkgroup between the two properties... I just haven't done enough scanning yet to confirm that.
The other talkgroups mentioned earlier in this post have been silent.
Forts
Ontario, Canada
Just for reference, many of the big casinos in Vegas are Cap+/Con+ and run BP w/RAS. Pretty effective when you think about it. RAS blocks you from using a radio to guess the BP code, and BP blocks non-Moto radios that don't care about RAS. Now that being said, I assume the custom Uniden FW for the SDS etc that lets you enter privacy keys would be able to get around this.
XBrandonEdwardX
Telecommunications
Niagara Falls
That would make sense if they were using Restricted Access to System (RAS) in "Migration" mode which allows radios that are/aren't capable to be able to use the same system. There are other pros to that too, such as not having someone nearby using the repeater's input frequency to listen to radio comms as that would bypass RAS all together. Also, with it being a dynamic trunked system, with the talkgroups moving around to new rest channels, it would make it harder to listen too.
Also, an important to note... that "bypass" won't work if you're trying to do it from a Motorola radio. If they are using RAS, their radios transmit the packets needed for that feature. Motorola radios don't know how to decode or ignore those packets... hence why you have to put the key into the software... that way the radio is pretty much like "hey, I know that key, let's listen!"
XBrandonEdwardX
Telecommunications
Niagara Falls
More talkgroups are starting to popup for the Niagara Fallsview Casino Resort site... All are encrypted.
Code:
Cap+,      13349,     14,         50,    High,       7,  2025/10/16 11:25,  ""
Cap+,      13349,     19,         50,    High,       1,  2025/10/16 11:19,  ""
Cap+,      13349,     22,         50,    High,       4,  2025/10/16 11:26,  ""
Cap+,      13349,     27,         50,    High,       3,  2025/10/16 11:32,  ""
Cap+,      13349,     28,         50,    High,       7,  2025/10/16 11:30,  ""
Cap+,      13349,     31,         50,    High,      13,  2025/10/16 11:22,  ""
Cap+,      13349,     108,        50,    High,       7,  2025/10/16 11:30,  ""
XBrandonEdwardX
Telecommunications
Niagara Falls
I think I may have been mistaken about the casinos using IP Site Connect (IPSC) to communicate between Casino Niagara and the Fallsview Casino.
A recent YouTube video showing Fallsview Casino security personnel on Fallsview Boulevard shows several personnel carrying what appear to be thin, WAVE-style radios with plastic holsters. I’ve attached a screenshot from the video showing the radios in question.
After doing some more research, I now believe the IPSC traffic I was seeing may actually be related to the MOTOTRBO system communicating with a WAVE PTX Gateway.
I have plenty of experience with Motorola products, but I've never personally worked with WAVE PTX. However, Motorola's own WAVE PTX documentation confirms that the Gateway connects to MOTOTRBO systems over IP, using parameters obtained directly from MOTOTRBO CPS, including the Primary Repeater IP Address, UDP Port, MNIS settings, and Link Establishment information.
Motorola also documents the specific IP/UDP communication between the Gateway and MOTOTRBO repeaters.
So, rather than the casinos necessarily using IPSC... what I was seeing may actually be the repeater connecting to the Gateway using the same IPSC criteria.
Forts
Ontario, Canada
When I was there a month ago, security was definitely using DMR radios. I saw some with XPR7550s and some with what looked look SL3500s. I'll be there again later this week and will keep my eyes open.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
That looks like an SL3500 and yes, when I was there last year, they were using a two site Capacity Plus system. IPSC is only used for linking conventional repeaters, nothing to do with Cap+.
XBrandonEdwardX
Telecommunications
Niagara Falls
My bad! I meant Linked Capacity Plus (LCP). I used the wrong terminology… but from my understanding it’s the same concept… If you look up at my DSD from a while ago, I was picking up LCP packets, not IPSC.
You might be very well correct. I was there not that long ago on a Thursday… when they were setting up for the Backyard BBQ and they were 100% using these radios along with the XPR 7550e models. I referenced the video with a screenshot as proof.
