64 tgid’s per system/knob position(max the pps will allow) but you can link up to 8 knob positions.Was it 64 per system of for the entire scan list?
In your video, the PPS C7 PTGL indicates the TGID Max is 64 per system. This would still restrict me to 64 TGs per system no matter how many TGs I enter across multiple Knob positions if they are in the same system, correct? If so, is Unication planning to remove that limitation?Scanning between MULTI Knob positions
UPDATE: It appears we can scan upto 64 TG in a knob position so when I say a total of 64 that seems wrong appears 64 per knob positions..
Yes 64 TGID’s per system. But when 2 knob positions are linked that becomes 128 or more depending upon how many knob positions you link.In your video, the PPS C7 PTGL indicates the TGID Max is 64 per system. This would still restrict me to 64 TGs per system no matter how many TGs I enter across multiple Knob positions if they are in the same system, correct? If so, is Unication planning to remove that limitation?
Nice work Jeff ! Are there plans to update the display by offering more characters up to 16, or maybe remove the [parenthesis] ?New Alpha 2 firmware released today,One thing we now can change delay between systems(sites) from 1-600 sec.Also they added SITE HOLD.
Check out short video with that feature ALPHA 2
Thanks for the info. To add more to the conversation and make sure that I understand correctly... I should be able to enter all of the TGs for Montgomery County Ohio (one system and many more than 64 TGs total) across multiple Knob positions and then link those knob positions, scan the linked Knob positions and then be able to see the Alpha Tags associated with each of these TGs as they become active?Yes 64 TGID’s per system. But when 2 knob positions are linked that becomes 128 or more depending upon how many knob positions you link.
It is a tgid scan mode. So if your system has more than 64 tgid’s or you want to listen to more than 1 site/system you will need to link more than 1 knob position to hear them all. The other thing is you will only see tgid alpha tags (64)for the knob position the pager is on but hear and see tgid numbers for all other linked systems. If you have 2 systems you want to hear with with 64 tgid’s you can put all tgid’s in knob 1 position with 1 system site info and set up knob 2 with the Other system site info (With 1 tgid,pps requirement) and link them and it will scan both systems and you will see alpha tags for both. That’s the best Case scenario I’ve seen so far to see alpha tags.
*If this is incorrect please correct.
This is still in alpha beta and subject to change.
Yes for linking the knobs but no for seeing all alpha tags. If you have knob positions A,B,C linked and the pager is physically on position A, you will only see alpha tags that are in knob position A but you will still hear B,C but only see the numeric tgid. If you are on knob B it will see those alpha tags but not A,C. You can be in knob position D ,even though it is not linked at all,and still hear A,B,C but you will not see any alpha tags. Only the numeric tgid.Thanks for the info. To add more to the conversation and make sure that I understand correctly... I should be able to enter all of the TGs for Montgomery County Ohio (one system and many more than 64 TGs total) across multiple Knob positions and then link those knob positions, scan the linked Knob positions and then be able to see the Alpha Tags associated with each of these TGs as they become active?
Thank you. That helps! I love the G5 and look forward to future firmware and product updates.Yes for linking the knobs but no for seeing all alpha tags. If you have knob positions A,B,C linked and the pager is physically on position A, you will only see alpha tags that are in knob position A but you will still hear B,C but only see the numeric tgid. If you are on knob B it will see those alpha tags but not A,C. You can be in knob position D ,even though it is not linked at all,and still hear A,B,C but you will not see any alpha tags. Only the numeric tgid.
It’s kind of confusing when not physically doing the steps and things could still change so I‘d be hesitant to post a video of the steps until it’s in beta unless someone wants to.
I’m not a software/hardware engineer so this statement could be wrong but it appears that the pager is possibly not able to handle more than 64 tgid’s in 1 system at a time. Or they may just not want to put the man hour cost into going that deep with it at this time. Or maybe they are planning to build a scanner. Wishful thinking but it doesn’t hurt to dream. Either way this is a plus for the scanner(Multi site/system scanning,tgid hold/delay etc.) and duty users (tgid hold,tgid delay)
Scanner dreaming is limited to this thread.Wishful thinking but it doesn’t hurt to dream.
* Update: when in PTGL scan list you must put tgid’s in the linked knob and the knob the pager is on to see the alpha tags. I was mistaken and thought we could get by just linking the knob with the site info to the knob with the tgid to get alpha tags.Yes 64 TGID’s per system. But when 2 knob positions are linked that becomes 128 or more depending upon how many knob positions you link.
Live not best quality video ,sorry.The G4 is scanning between 2 knob positions.
