- Joined
- Jul 5, 2011
- Messages
- 545
- Reaction score
- 220
Thought I would post my thoughts for people like me that read these things before they dump cash.
The positives: It does track P25 phase II. It does DMR. It is a GREAT footprint, and is very, very tiny. It acts like it might be a little tough against bumps and lumps you would find with people that take scanners places and don't treat them like queens. The display is very readable in all weather conditions, in and out of a vehicle. You can make it highlight and emit a tone for things you really don't want to miss. The audio can be very, very adequate. It will record voice traffic. The drop in charger is handy. And, it looks... professional, if that's a thing that appeals to you (it does to me to a point). Updating software is straightforward, and squirting a mission plan into it is also fairly painless. It has a lot of options... a lot. So, if you enjoy a product customized to your particularities, you will appreciate this. It has a removable antenna so you can hook an external to it, or to its' base. And, if you have access to the keys, it will decrypt secured talkgroups / channels. It has several positions on the knob, and a lot of zones, so you can put a decent amount of things to monitor into it (if you can remember what went where lol)
Stuff I wish weren't so: It is essentially a one-trick pony. By that, I mean it is only good for listening to a single system. You cannot really get it to listen to a trunked system and to conventional channels. You cannot (as far as I can tell) alter the programming from the receiver, at all. What you loaded is what you get, warts and all. The programming software has a steep learning curve that is still rough even if you come from Harris military or Motorola RSS. (I can sort of explain their concept now). You have to accept this was designed as an overthought fire pager, and the fact it does some things beneficial to the rest of us is an afterthought. You can give up on any real written guides, and very few videos that really click. There isn't really much in the way of paid assistance or codeplug building for you. The external antenna is for one band only (you don't get to choose), the other is buried inside. You only get the choice of two bands, 800 and either V or U. The knobs on top are too close together for man hands, changing a knob position inevitably changes the volume. You have to be careful about the antenna port; some connectors with flat faces will push the center pin in and ruin the port. Service after the sale is iffy, they won't fix older units. The connector for programming and charging (if you didn't spring for a base) apparently doesn't suffer abuse much. There are few accessories for it. The older antenna for 7/800 is trash if you are borderline fringe area or mobile. Keyloading is... particular (all KVL's are, but this one likes to be extra). It does not like having a lot of talk groups to sift through on a single knob position.
Stuff that might be me, or where I live, or the system I monitor: Sometimes it just doesn't want to give me certain talk groups. I can change the knob one over, and it does just fine. Many times, you have to power cycle it. I haven't found an antenna that gives me adequate coverage for where I want to be when I am mobile. It's an older unit, perhaps it is tired. When it fails, you don't know you aren't listening anymore.
Overall, I am disappointed with it. It would make an excellent window or desk scanner on an external antenna. I would not trust it as a pager in the hills of Southeast TN though. I think I'm going to make one more antenna test, and if that doesn't do it, I am going to look at NAS harris radios and throw this one up for sale.
Again, because this is RR, this is one opinion based on things that aren't your things, with a used unit, on a particular system, in a mountainous terrain, and if they don't have an active radio dragged to that tower, you aren't probably going to hear it, and this is a fire pager, not a scanning monitor. I am not sure I have correctly programmed it, either.
So, if you need a plug and play monitor, this is very not for you. If you like to tinker, you may find fun here. IF you need assured receiving, and don't have a radio shop to issue this to you... mmmm I dunno. Others will tell you it's great, some will say it's garbage, I am mostly in the middle.
