Gas Leak
Rolfman
Tooele
Looks like they have determined the southern perimeter is Sunnyside
1518hrs: Command says they have a west perimeter, anyone catch where it was?
Utah_Viper
North Muskegon, MI
SCLFD sending units to 1325 E 500 S for injuries on a fall on a vic who was walking out of the zone as well
SLCFD now reports an unconscious person @ U of U ( bldg unkown) 590 s Wakara wy...
1518: 25yoa Female, conscious and disoriented @ the registration desk @ the address
what channel you getting that on.... im trying to find what channels are active.
Rolfman
Tooele
1520: This is at the U of U Orthopaedic center
Sounds like gas is getting in to the buildings. Not good.
All it needs is one good source of ignition.
tyler1653
Farmington
So, how do gas leaks like this work. Do explosions actually ever happen and what does it take to set them off? I've heard so many gas leaks paged in the past and I don't think I've ever heard of something blowing. Can the fumes be backing up into homes/bldgs/etc.? Is natural gas as flammable as propane or something like that?
Utah_Viper
North Muskegon, MI
I have seen video of entire neighborhoods being wiped off the face of the map. It just takes one tiny spark if there is that much gas.
Rolfman
Tooele
Depends, most leaks hit the air and disperse and are not a problem except for right at the hole. It sounds like this one the construction crew was boring and hit the line so it had seeped in to the sewer system. Now the gas is concentrated, has oxygen, and can find it’s way in to buildings that have a source of ignition.
Yes this is natural gas.
PS: Yes it gets in to the homes and building through vents. The sewer line connects and runs throughout but there are vents on the roofs to let the sewer gases vent. So basically you're whole drain, waste, and vent system in your home could be full of NG.
My couch in PDX
It also looks like the evacuation is causing problems of its own: FD just send 3 units on a trapped person at one of the huge apartment complexes......."persons trapped in elevator" at the Incline Terrace apt bldg.
U of U PD VHF is also reporting they are sending UUPD units to 1300 E 400 S for traffic problems
Rolfman
Tooele
Sounds like there are some levels coming down. Judging from the KSL pictures they have gotten the ground opened up near the leak and they have been pulling manhole covers on the sewer to get more air in there.
Also sounds like the HAZMAT guys have a good perimeter now on the gas in the sewer lines.
Rolfman
Tooele
All those old buildings down there. New buildings are required to have emergency power for their elevators to keep that from happening.
Rolfman
Tooele
You know someone needs to buy these guys some beers after this. They have reacted promptly and effectively. Good control of the situation and deployed the resources as needed to the areas as they arrived. I'm impressed.
My couch in PDX
Some very BIG beers at that/
LOL gas leak afterparty........the pie....1275 E 100 S!
Rolfman
Tooele
Does anyone know if Trax is still running?
That had shut it down up there around the leak, not sure how that affected service every where else.
1601Hrs:
I don’t know who that contractor was doing the work but stick a fork in them because they are done!
Pretty good pictures on KSL.com
1612Hrs:
From KUTV Questar officials say a 6-inch plastic gas line was broken sending gas from the ground where the crew was digging. It also seeped below ground into drain and sewer lines.
