bugger78
I cross the Kingston - Rhinecliff bridge often and encounter what I believe to be DMR transmissions. It effects multiple channels, like 4, 7, 14 and 22. Essentially the radio is useless when I'm approaching or on the bridge and it seems to have gotten worse the past few months.
I've used two different mobile rigs, the Midland MXT500 and the Wouxon KG-1000G plus and both exhibit the issue. However the Wouxon seems more sensitive and will keep squelch open over most of the span.
So the question I have is, are GMRS radios designed to be susceptible to these transmission and others, or is there a deeper issue at play?
