SDS100/SDS200: GPS stopped, not displaying, working.
woodtrol
indiana
I’m using a relatively new gps kit from uniden, connected to an sds100. Latest firmware. I’ve had the radio for a few days and I have it set up in a vehicle.
It worked great until today and the gps stopped. I’ve tried all I know to do, is there a way to troubleshoot the gps, like see the actual location display? There’s a red light on the adapter plug but otherwise these seem to have no indication of operation.
Really odd that it just stopped, and disappointed that it failed this quick. The baud rate is 4800, and the scanner is connected with the charging usb/gps port.
Help!
Thanks.
dave3825
Suffolk County NY
woodtrol
indiana
Well that’s exactly what I wanted! Unfortunately it’s showing no gps information.
woodtrol
indiana
FYI. I’m not sure if charging and using gps simultaneously caused excessive heat, or if it was just by chance, but I pulled the battery out and let it sit for about 5 min… reconnected and powered up with gps location again… hopefully it’s good to go.
nessnet
Eastside of Lake WA
You would have to read this manual but basically you need to edit the items on your scanner display. It can display Lat and Long
That - and looking at the GPS icon.
The lat/long on the display will show when the GPS is locked.
The GPS icon shows if the radio is seeing the GPS.
Do you have the GPS icon?
If no, check your baud rate, like a couple of others have said.
If the baud rate is correct, then the GPS went south somewhere.
Personally, on an SDS100, I'd go with:
https://www.amazon.com/gp/product/B07JQFHLBL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
and
https://www.amazon.com/gp/product/B00AMAJFUO/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
ofd8001
Louisville, KY
Oh I'm sure the GPS stuff is "new and improved" since 2018 :)
One way of trouble shooting GPS functionality is:
1. Disconnect GPS
2. Turn on Full Database
3. Enter a zip code of 90210 (assuming you are not in Hollywood)
4. See if the scanner loads "stuff" appropriate for Hollywood CA
5. Reconnect GPS
6. See if the scanner will load "stuff" appropriate for your home area. If so, GPS is working fine
n1chu
Farmington, Connecticut
Sounds like a hard reboot was needed. You accomplished that with the battery removal. I’d also verify baud rate…
JoeBearcat
Uniden Representative
Beverly Hills, actually.
a417
(If the OP has access to one) [I'd] check the data pin on the GPS to see if it's putting out a valid serial stream. I did this when I was cobbling together my original GPS mod for my SDS100.
The op doesn't need anything like a HP/Agilent/Keysight to do this, I used a USB Hantek unit that I really have come to enjoy using. If the OP also wants to dabble, I'd recommend the Hantek HT6022BE for a super-entry level.
Ubbe
Stockholm, Sweden
I took a look at the reviews and a $100 Zeeweii DSO2512G actually works to measure signals, where that $50 Hantek will have some issues, and are a portable scope with its own display, no need to connect to a PC to get a picture. I will probably buy one as my 40 years old 20MHz scope are too big and clumsy.
/Ubbe
Randyk4661
Garden Grove, CA
Help!
Thanks.
I've had the same thing happen with mine. No changes, just stopped working.
Double check settings if you have done any recent programming from software. That's the biggest problem I've had. Sentinel and proscan don't always download the most current settings between them.
nessnet
Eastside of Lake WA
It is always advisable to customize your display to show lat/long.
Then, you always know when you have a GPS 'lock' - or not...
ProScan
Software Provider
Ontario, Calif.
They should. When making changes at the front panel, use Sentinel to read the FL and use ProScan to read the FL so Sentinel and ProScan will be in sync. If making changes in Sentinel or ProScan, then write to the scanner then read back using the other so everything is in sync.
donc13
Grand Junction, CO
If the GPS "puck" is not blinking, no GPS lock!
Not all GPS pucks blink. The uniden SGPS does not blink. In addition, I have my SDS200's screen display the lat/long and before it GPS puck locks, the screen shows "no GPS"
