mrlightfoot
ok who pulled the plug?? radio system went down!
New TGs
56081 Burke Operations
56064 Cleveland Hopkins Utilities
56398 Middleburg Heights Fire Dispatch
Monitoring traffic on TG56029 Region Inter Op Call In. The traffic is snow plowing??? Radio id's are 1842xxx which is Cleveland Hopkins.
Also hearing traffic on Hopkins Ops 2 TG56063 and Hopkins Field 2 TG56058.
From my perspective I think that TG56081 should be changed to Burke Field Maintenance or just Burke Maintenance.
Can somebody explain what all tbe Region talkgroups are for? Happy Holidays.
I live in Cleveland (Westpark) and have a discone antenna mounted 30 feet above ground with good coax connected to two BC996T scanners via a Stridsberg multi-coupler. I found out after much experimenting that this antenna system may have actually hindered my ability to listen to GCRCN.
I noticed that I wasn't able to pick up ANY traffic depite full signal strength. I tried using the telescopic antenna plugged into the back of the radio that came with the scanner and found that it immediately solved the problem. I think I could be too close to the GCRCN tower sites, and my outdoor scanner antenna system was causing the scanner to become overloaded. The P25 audio and decode is very good too, hardly any garbled transmissions. I thought I might post this in case people in Cleveland or close to a tower site were having the same problem.
I heard the Hopkins snow removal traffic, as well as other varying comms, which got me wondering...In both of the above cases the Region TG's are being used to handle over flow traffic from system users. So (for now at least) it looks like the TG's are available to system users when their full time assigned TG's are tied up.
Is "overflow" an actual capability of the system, i.e. do the radios automatically switch to these reserve TGs when needed? How would this work?
Changed to BKL MAINT -- Maintenance
Airfield Maintenance? Building Maintenance?
Many larger and/or busier airports have those functions separated out on separate talkgroups since airfield maintenance involves FAA clearance.
At CMH we're using CMH AFM for airfield maintenance and CMH MTX for building maintenance.
