GS Parkway Radio System
mondaro
Harrison, New Jersey
Joe...
Does the feed carry Turnpike and Parkway or just Turnpike. Thanks again for providing the feed I wish it was 24/7.
Take Care
Tony
jcardani
Orlando, FL
Hi Tony,
Turnpike only, the Parkway system is way too weak for reliable reception and my program can only scan one system at a time.
jcardani
Orlando, FL
Due to the severe weather forecast for this weekend, the feed is back online monitoring the NJTA NJ Turnpike Operations Passport trunked radio system.
Feed address:
http://phillyscanner.bounceme.net:5000
To listen in Windows Media Player Click File .. select Open url, then enter the above address and click OK
To listen in Winamp ClickFile .. select Play URL, then enter the above address and click Open.
enjoy
jcardani
Orlando, FL
Please let us know about the 800 Mhz freqs because the parkway ops use the same Passport system as the NJTP.
RadioDitch
Field Operations Member
Not Where You Think
Someone actually just gave me a Moto CDM1550LS of the 200MHz species. The radio does LTR PassPort. With a little help and intelligence would it be possible to program it for the Turnpike/Parkway System...likely for a live feed of the Parkway to compliment the inclement weather feed on the Turnpike?
Also a note before anyone says anything about it affiliating or such...
**Transmit does not work on this radio, and I have no intentions of making it work. Receive is fine.
MPFD535
NJ
No it will not work, you need a access number for the radio to talk to the system, works like a Motorola trunk system, an if you make one up it can be dangerous just like it can with any other system.
RadioDitch
Not Where You Think
So it won't even receive?
Again, transmit *does not* work on this radio, and I have *no* intentions of making it work. Interested in using it receive only...
rmosier
Mt. Olive,NJ
So far I haven't received any traffic at all. (I'm located in Budd Lake with a discone at approx. 25'). I should be able to receive no?
GM
I believe they have the capability to use them in case all else fails, as I hear an occassional key-up on the 800 MHz freq's (all 4 of them) and the VHF-Hi freq of 156.12000 (151.4) from Holmdel. I have them in my scanner, but have not heard any voice activity on them since the 217 MHz TRS went live a few years back.
jcardani
Orlando, FL
Feed address:
http://phillyscanner.bounceme.net:5000 or phillyscanner.bounceme.net:5000
To listen in iTunes Click Advanced .. Click Open Stream, then enter the above address and click OK
enjoy
jcardani
Orlando, FL
Pretty busy right now. Can you guys access the feed? - I only have one person listening. This feed is usually more popular than that.
thanks,
GM
I tried to listen in just now and the link won't load up. Not sure if it's from my computer or the fact that their are sporadic power outages in my area, and I'm working off of a wireless laptop on the wi-fi signal. No access to my regular computer at this time due to a power outage. But I do like to listen in when I have the time to... :)
