Help! with SDRSharp and DSDPlus.
AngWay
Curious
Buchanan, Va
Can someone please help me with this i am trying to stream audio from sdrsharp to dsdplus with the sdrsharp plugins but i'm having problems with the input and output audio. i have already got everything set up the way it's suppose to it's just my settings that is messing me up i will add some screenshots showing what i got so far if you could help me i appreciate it alot! and please understand i'm not that familar or smart with these things i'm a noob and learning if u could show me screenshots of what your talking about it would help a lot better. anyway thanks alot!
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Why aren't you using FMP/FMP24 to communicate with DSDPlus? At any rate, the settings look okay, at least the ones I can see. Remember, it is a DIGITAL Speech Decoder. That means it wants to decode digital signals. If you just park on dead air, I'm not sure I understand what you are expecting to here. Find a digital signal that it can decode, and then if it is digital voice you should hear the output. If it's a digital control channel, you won't hear it.
You're running the ancient free version, with SDRSharp. I did it in the past too, when the software first came out. But it's not optimal compared to using FMP/FMP24 and DSDPlus.
AngWay
Curious
Buchanan, Va
well i have fastlane i tried it with it but i had issues i have tried following guides online what i'm getting now is i park on a control channel and dsd doesn't scroll like the way i'v seen in videos it just sticks in the same spot if i move off the control channel a tiny bit it might start scrolling but other than that it's no doing anything and in sdrsharp i can't control the volume i can't even mute my whole pc it's weird idk i'm sure i'm doing something wrong but idk what.
mtindor
FMP24 PRO USER
If you have an RTL dongle, and the RTL dongle works (you did the Zadig thing). Then, assuming you didn't butcher the FMP24-CC.bat and 1R.bat batch files and they are pristine, all you have to do is fire up FMP24-CC.bat and 1R.bat and boom. You're up and running.
I didn't see you parked on a control channel in your screenshot - looks like you are parked on dead air.
When you start throwing in third party apps (SDRSharp, various plugins in SDRSharp), then you can expect issues and you can expect not a lot of answers from the rest of us because most of us don't use SDRSHarp and DSDPlus plugins because you can't trunk anything that way. With FMP24-CC.bat and 1R.bat, you can actually trunk a system if you want.
I'm sure I could figure out whatever issue you are having there, but I'm not in front of it. Hard to diagnose the problem over the forums, and for most of us we are warn out trying to explain these things that have been explained hundreds of times since the original DSDPlus came out.
If you have SDRSharp started and you have it set to output to the VB cable, then you have problems if you aren't seeing any audio signal in your sound settings in Recording or Playback (I forget which) for the VB Cable. You should be seeing a green signal, which would tell you that the audio out of SDRSHarp is actually passing through the VB cable.
