Help with Unication info
bobruzzo
W1AV
Cranston, Rhode Island
Thank you for helping but I gotta run out and get dinner but will be back here around 6pm if you are still able to help or we can pick it up another time when you are free. I really appreciate the help....bob
OK this is what I have.......but it doesnt look right....not showing all the right info
That isn't correct...Not sure what you clicked on but lets back up and try again, by the way, doing great just a learning curve, you'll get there.
On the E2 screen it should look like this...
You want to click on add (see arrow below) and select add system from Resources (underlined below) add the five sites you see.
You will see a box with the 6 sites you have in C1 click the box to the left of each one and add them in E2
After you go to Tab E4 and add your protocols, I suggest you add all available protocols, by clicking add and clicking on the name. You DO NOT need to change anything below the list, just add the protocols and rename them to match protocol type.
Now you are almost there and ready to add the systems. Let me know when you are done and share screen shots, TIP: All screen shots should match mine, if not figure out what is wrong/where there was an issue.
bobruzzo
W1AV
OK I must have made a mistake...my E2 screen looks good but when I add system from resource I get whats in picture. I am still missing a step or forgetting something. When I click on the BOTTOM one it just duplicates the top one. I keep making the same mistake but dont know I am making it. I might have to start over cause I cant find the problem.
Let's go back and look at C1 and make sure they are there. It might have been lost if you didn't click save at the bottom.
bobruzzo
W1AV
when i click to add, i get drop down list of freq ranges. I pick the one that I been picking then get pop up like this: its not right, things missing.
The instructions are above, in post #71, you are importing from RR
OK I already have the METRO site done, now I will import the NORTH site.....
This is what it should look like, AFTER YOU UNZIP IT what you need to do is go to E7 (at the bottom) and select the TG you want to add for each knob position. You need to unzip the file and go to Tab F1 and import the file AFTER YOU UNZIP IT.
  • RISCON_V0.4.0.41 _Sample006_250417.unipps.zip
bobruzzo
W1AV
OK I will do this
bobruzzo
W1AV
OK I imported the file you sent....heres what it looks like in the E2 P25 trunking system setting.
