Here's a excerpt of the NEC Article # 250.70 Methods of Grounding and Bonding Conductor Connection to Electrodes.
" The grounding or bonding conductor shall be connected to the grounding electrode by exothermic welding, listed lugs, listed pressure connectors, listed clamps, or other listed means. Connections depending on solder shall not be used. Ground clamps shall be listed for the materials of the grounding electrode and the grounding electrode conductor and where used on pipe, rod, or other buried electrodes, shall also be listed for direct burial or concrete encasement. Not more than one conductor shall be connected to the grounding electrode by a single clamp or fitting unless the the clamp or fitting is listed for multiple conductors."
This means that you must use a UL listed clamp that's designed for grounding purposes and needs to be listed for the same material type for the pipe and ground wiring type that you are using. Usually this translates to using a UL (listed for USA, or CSA for Canada or an LR rating for Europe) listed clamp that is listed & designed for connecting a copper ground rod to a copper grounding wire. The electrical guys at Home Depot can help if you give them the right information on the material types of the ground rod, existing cold water piping and wiring that you are using. Also if you happen to posses any aluminium wiring and intend to use it...Please Don't... unless the clamp is designed for aluminium wiring and is marked with the AL/CU stamping.
