txscan
I have read the manual and not understanding how to turn on group quick keys, one system quick key that I have programmed has 2 group quick keys in it, how do i turn on and off the group quick key?
Mine works just as described in that section I gave you the link to. How is yours not working?maybe i am doing something wrong, but it is not working
Just remember to be sure that you are in the system that contains the group you want to toggle. It can be tricky.maybe i am doing something wrong, but it is not working
If you are scanning multiple systems, you have to be quick on the function key to stop the scanner on the system you want to change. If you miss the system you want to change just use the scroll control while holding the function key down to dial up the system you want to change. Then press the numbers of the groups want to enable/disable.garys,
i think thats where i am messing up, ill figure it out eventually
