Hytera MD-652 Question
bferguson1121
How do i get this mobile to turn off and on whenever i turn my vehicle off and on? I know this sounds lazy but i do get tired of turning this radio on and off everytime i get in and out of the vehicle. I know i would have to wire the radio into a 12 volt hot wire that would be controlled by the ignition but once the radio recieves power i would still have to press the power button to get the radio to turn on. Any suggeswtions would be greatful, thanks!
AYoung2600
Ohio
The main power wire for the radio needs to be ran to a 12 volt constant power source. You then need to run an ignition sense wire off of the accessory connector on the back of the radio to your ignition controlled power source. If my memory serves correct I believe pin 26 is ignition sense.
