Icom shows new IC-R15 at Tokyo Ham Fair
eorange
♦RF Enabled Member♦
Cleveland, OH
I never considered Icom (and Yaesu too, for that matter) to be true competitors in the scanner market. They make communications receivers. The typical blunt reaction is "what's the difference?!", but for those who have spent significant time with both...there is a difference in features and purpose.
That's why I don't think Icom concerns itself with the ramifications of encryption.
satellite909
Tampa, Florida
Very true. There are some individuals that regard Communications Receivers as scanners. Those that are interested in digital encryption modes for public safety, EMS, etc., then a Uniden scanner will do.
bearcatrp
Land of 10,000 taxes
Icom does make or has made receivers with P25 capability. The R30 and R8600. Both do well with phase 1 P25. If indeed encryption will cover the country, why put it in a receiver or scanner? Am sure it costs a bit to install it but makes the scanner/receiver less expensive without it.
satellite909
Tampa, Florida
I say why not too! My play on a perfect all band, all mode, digital and analog receiver: design and engineer every available option, phase, encryption, decoder chip there is with a full-color large easy to read display with waterfall in a handheld communications receiver. Nice to dream though, but I know it could be done.
AK9R
Central Indiana
Icom may make receivers that can decode P25, but do they make trunk tracking receivers? Without trunk tracking, a P25 receiver is just a receiver, not a scanner IMHO.
satellite909
Tampa, Florida
That is true and Icom does not or will most likely never produce a trunk tracking type of receiver.
bearcatrp
My R30 has all the P25 frequencies in my state. Can select my county only and receive both sides of the transmissions most of the time. Almost as good as my 436 did. Not a trunk tracker but it gets close provided you program it right.
eorange
♦RF Enabled Member♦
Cleveland, OH
100% on this. It works better than you'd think!
satellite909
Tampa, Florida
That’s good to know. I’m actually about to purchase the Icom ICR-8600 new. Looking forward to trying the P25 on that one. I should have grabbed the ICR30 back in the day when it was available.
xms3200
Cleveland, Ohio
For all the R30 owners...I hear you do not need a filter for VHF Airband since it is built into the Icom R30...any thoughts on the upcoming R15, since the "Trend is your friend", I am thinking it has built in filters like the R30
palmerjrusa
Frederick
All I can say is when scanning the UHF military aviation band:
With my AR DV-10 I need the filter blocking the FM commercial region otherwise there's constant intermod interference.
With my IC-R30 (both of them) I don't need the filter, very occasionally I get intermod break-ins, but they're very transient/brief.
I will be buying an IC-R15 and I expect that radio to meet or exceed the performance of the IC-R30.
My experience with Icom gear is that it does what Icom says and does it very well...
satellite909
Tampa, Florida
With my AR DV-10 I need the filter blocking the FM commercial region otherwise there's constant inermod interference.
With my IC-R30 (both of them) I don't need the filter, very occasionally I get inermod break-ins, but they're very transient/brief.
On my ICR6, the UHF Military Aviation band I’m thinking is dedicated with build in filters.
From what I’ve been seeing on YouTube and reading about the new ICR15, looks like it will an excellent performer on all air bands. ✈️
palmerjrusa
Frederick
Same with my IC-R6s.
I've ended up with three of them, one black, one red and one blue...
palmerjrusa
Frederick
Woo hoo! I just noticed the IC-R15 uses the same Li-Ion battery pack, AA battery pack, and drop-in charger as the R30. This is great news for us R30 owners, especially the continued availability of the Li-Ion battery pack.
The alkaline battery case for the IC-R30 works great too.
Its actually a little wider than the Li-ion battery and makes the IC-R30 more stable and less prone to knocking over since the radio has a narrow form factor.
