Internal GPS Mod Tech Support/Q&A
jonwienke
More Info Coming Soon!
VA
FYI, my "real" job starts a 12-hour, 7 day schedule on Monday. I am still doing GPS installations, I just won't be able to guarantee my usual week or less turnaround from now until sometime in January. I'm going to finish the work I have this weekend, but any new work will take longer than usual.
Astrogoth13
City of Angels, CA.
I haven't had anyone interested in having me mod one yet. But I know it is doable, others have successfully installed the Ladybird GPS in a HP-2. I'd have to take one apart to be sure, but I believe that a Reyax module could be installed, if one was willing to make a cutout for the GPS patch antenna.
I have an HP2 for you to experiment on. It's an expensive radio but an internal GPS would be neat and worth the risk. Interested? What would you charge?
jonwienke
VA
$75, same as a 436. I would need to open the unit to see where it would be physically possible to put the GPS, and I would let you know before making any permanent changes to it. Fair enough?
tomas4569
I've decided to try and do this project myself but I was wondering. What is the difference between the RY636AI and the D1 model?
And does the D1 need the rs232 converter?
Sent from my SM-G930T using Tapatalk
jonwienke
VA
DI outputs RS232, AI outputs TTL.
RS232 is preferable, because you don't need the conversion chip, which will use any excuse to let out its magic smoke.
The 636 is only suitable for mobile scanners. The RYN25DI is better for handhelds.
wbswetnam
DMR-istan
If the GPS won't fit inside the unit, perhaps some external attachment to the display base would be feasible.
jonwienke
VA
I would only consider the RYN25DI for the HomePatrol due to size considerations.
jonwienke
VA
Due to higher than expected demand for my services, I’ve temporarily run out of GPS modules. I have more on order, but it will probably be about another week before they arrive. I'm still in business, but your patience is appreciated.
JamesO
McLean, VA
I guess this is a good kind of problem to have with the exception of the people waiting on the modifications!
Universaldecoder
Michigan
Jon, how did you verify that there are no noises being introduce by the GPS module being so close to the internals of this scanner?
jonwienke
VA
The mod includes a power switch for the GPS.
When there is a background noise you suspect is caused by the GPS, turn it off. If the noise suddenly goes away, and resumes when the GPS is powered back on, it's caused by the GPS.
I also used a SDR on a USB extension cord as a RFI sniffer, comparing GPS on/off RF dB values on a variety of frequencies with the SDR antenna next to the GPS module.
The Reyax module is the only one that passed both tests with no detectable RFI on any frequency I have tested.
tomas4569
RYN25D1
I've successfully modified my radio and have already gone thru two of these modules. They work for about two to three weeks then just stop working (no GPS fix). The scanner still shows the GPS in the bottom right corner and the settings haven't been changed. But it doesn't get a fix (blinking red), although on power up I see the lights, fixed and steady green and a quick red flash from the other.
Do you have similar issues with your modules? how do you trouble shoot this?
jonwienke
VA
I have had one customer report a similar failure, but haven't had the chance to do a post-mortem yet to see what happened. Look back in this thread for a link to the u-blox test and diagnostic utility, that may offer some clues to what happened.
Note that the module is susceptible to damage from static discharge into the patch antenna. That is the most likely cause of sudden failure after several days of operation, given the absence of heat buildup in the modules.
tomas4569
What do you use to protect the module?
jonwienke
VA
I give the patch antenna several coats of truck bedliner, which closely matches the scanner case visually, offers some physical protection against bumps and scratches, and forms an insulating layer to protect against static discharges.
  • Like
Reactions: RRR
