The news of this release has been on "The Scanner Guys"
youtube channel for months, even had the initial
product announcement, before anyone else.
Yes, it does NXDN and DMR
Conventional. TRUNKING and P25 NOT INCLUDED.
NOT AVAILABLE.
WHAT they are NOT telling you (from what I have gathered): Some of this stuff matters to more advanced users, others may not care
1) Unsure if it displays the COLOR CODE or RAN. (or if it can be programmed for a specific code)
2)
WILL NOT DISPLAY TALKGROUP NUMBERS. So you won't know what talkgroup is actually transmitting. You won't be able to only listen to a particular talkgroup and not another one.
3)
WILL NOT DISPLAY UID/RIDs (Radio ID numbers). So you can't differentiate those talking or name the radios in the software
There is not enough room on the screen for this, plus with this type of scanner (Banks), I don't think it could work with a list of RIDs.
4) WILL NOT have "
1 FREQUENCY DMR" type "UNIDEN TRUNKING" programming. You just enter in a frequency and it decodes the audio, but is not giving you the information (if you want, like, or are used to it in the previous models). This does not have the architecture, this is a BANK memory. (hardware driven radio, not software)
We don't know what the future of Rail Scanning is going to be like when it moves to NXDN. There may or may not be any talkgroups in use, but I'm sure there will be Radio IDs. (some conventional NXDN uses talkgroups, but a majority just use "Group Call") 2 different railroads can use 2 different RAN codes. Are you able to program if for only 1 code (so you don't have to hear the other one?)
All I'm trying to do, it help those that just want to go out and buy one immediately without thinking about it's full capabilities. I have not found a manual PDF yet. All the photos that I've see are very generic. The programming software really doesn't show a lot either.
There is one photo that shows both "NFM and CAP+" on the screen, but it really doesn't make any sense, since this scanner is not capable of "CAPACITY PLUS"
One of the main photos for the item just shows the "Weather Priority" like that is the major selling point or something.
