Issues with PG County System on Openmhz?
villlythekid
Montgomery County, MD
Just checking if anyone else has noticed that a lot of tranmissions aren't even being uploaded to Openmhz for Prince George's county? I noticed this only started either yesterday or Sunday. On the other hand, Montgomery County seems to be working just fine. Maybe there's some way to get in touch with the feed provider? It has always been a reliable way to play back the things I missed on my BCD996P2.
maus92
The OP
PG North seems to be working - not sure what type of radio is feeding it however because it's not the best quality. If it is a non-optimized scanner rather than a good quality SDR / software package, it could be missing transmissions.
If you want to hear good fire radio, listen to the Anne Arundel County feed - something is always going on, and the fire officers tell you what is happening....
GTR8000
NY/NJ Database Guy
BEE00
There seems to be an issue with OpenMHz affecting all systems at the moment. Load any of them and you'll only see a few transmissions. If you refresh, it wipes them all out and starts over.
OpenMHz requires an SDR running the OP25 based software Trunk Recorder; there is no option to use a scanner or radio or anything else.
maus92
The OP
Good to know, so nothing like Proscan and a 996P2 could work? Not really not familiar with the requirements for OpenMhz; I guess I need to learn it.
Mr_Boh
The Land of Pleasant Living
It's developed by the same person (Luke Berndt) that makes Trunk Recorder. I am sure the API could probably accept calls in similar fashion to the Broadcastify calls program from other sources, but I highly doubt anyone is working on that. The software that powers OpenMHz is called Trunk Server, and you call pull the software yourself from GitHub.
villlythekid
I noticed that yesterday as well, however it seemed to fix for DC and Montgomery County, MD earlier today. Leads me to believe that it's an issue with the feed provider. However, overall I can say I have been very satisfied with the feed.
villlythekid
Thanks for the link. I noticed however it seemed to be an issue with only this feed. One of my colleagues reached out to Luke and he provided contact info for the specific feed provider(s).
