Issues with programming G1
KC3GXH
I have a G1 that I'm trying to update the codeplug on.
When I try the PPS (R03.07.03-R02), I get an error stating "Serial Port Connecting Error or Pager Firmware Version is not a match, Please check again"
I tried updating to FW RVV0114EN and keep getting an error code "52: Can't get G1 version or identify"
I freshly installed the PPS and FW this morning. I didn't open either until the pager was in the programming cradle and turned on. What am I missing?
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
Make sure you have the correct port selected and make sure the pager is seated correctly. I have noticed after changing batteries the screws are not all the way in and some pins won't connect with the base because they are holding it up.
KC3GXH
Everything appears to be ok. There's a symbol in the top left signifying (what I believe to be) data transferring (2 arrows facing opposite directions)
I confirmed the port I was using to be COM7 and the pager appears to be seated all the way.
