hornetd
I'm trying to figure out If I can use 4 rechargeable 3.2 volt LiFePO4 batteries in the AA battery shell for the TH-F6 radio. Total voltage would be 12.8 nominal. The PG-2W power cord connects to a 12 volt power supply and permits operation of the radio at full power. What I need is for someone with a service manual to tell me what the relationship is between that cord jack and the battery terminals. If the cord jack switched the battery pack out of the circuit then the OEM rechargeables could not be charged through that jack. What is the arrangement? Does the jacks internal connection go through a voltage regulator? Does the OEM battery eliminator adapter have a voltage regulator in it. I could modify the AA holder to put 2 cells in series and then put 2 such sets in parallel with each other. That would hold the voltage to the 7.4 volts that the OEM rechargeable batteries provide with more run time if I use the highest MA/Hr capacity available.
Any help would be appreciated.
Tom W3TDH
Tom W3TDH
