Looks Like Baofeng Finally Did It
ChitheadDeSo
Louisiana
I bought this radio last week and tested it out at the camp this weekend... Everything seemed to work well there was only one thing that I didn't know what was going on and the manual did not mention it. While in the deer stand I had the ear piece in, and after wearing it for awhile the radios voice would say something like "transmission overtime" or "recieve transmission overtime" I never quite heard what it was saying. Does anyone know what this means?
Rred
Many new radios, and I think all of the Chinese ones, have an option to conserve power. In case you forgot to shut the radio and put it away, or the power knob got turned on in your pack, after the TIMEOUT period it will prompt you and if there still has been no activity, it will shut down.
Check your manual, this is a documented feature. You can enable/disable it and usually change the time as well.
ChitheadDeSo
Louisiana
It only occurs when the headphone and mic is in, is that just part of it, kind of like we know your not looking at the handheld itself so we are going to warn you through the earpiece...
ChitheadDeSo
Louisiana
Thats cool, thanks for the help makes sense I will try and change that setting and see if it does anything and let yall know what I find out.
Leelorr
Sounds like the transmission time out feature
Most radios have a menu setting of how many minutes of continuous transmitting to allow before powering off to save battery life and possible burning out of the output finals. Sounds like maybe you accidentally might have had the transmit button pushed while sitting there. Easy to do in a pocket or if the radio is pushed against something while sitting, etc.
Delta33
Clinton Iowa
Its labeled TOT or Time Out Timer. ;)
ChitheadDeSo
Louisiana
After playing with it last night I have found that Leelorr is correct, and one of two things happened the latter being the likely culprit. One was that my mic on the headphones got stuck open somehow (which I could not reproduce last night) or the other was that I had the radio inside my coveralls and most likely was hitting the button while sitting without realizing. Either way thank yall for the help and I will look to be more cautious about positioning the radio as to not do it again.
jonwienke
More Info Coming Soon!
VA
Get a belt pouch for the radio rather than sticking it in your pocket. You'll be a lot less likely to have accidental discharges, and eliminate the possibility of other stuff in your pocket scratching or damaging the radio.
bill4long
Indianapolis
This Baofeng radio is unable to transmit on the shared FRS channels.
Yes it does. I have one, and it does. It doesn't xmit on the FRS-only frequencies, but it xmits on the shared FRS/GMRS frequencies.
The company clearly states this in the manual
You are mistaken. What page do you think it says this?
N4GIX
Hot Springs, AR
Of course it can transmit on the "shared" FRS/GMRS frequencies. What it cannot do is transmit on the "exclusively" FRS frequencies.
Dahwg
Tucson, AZ
Page 34
Sent from my LG-H918 using Tapatalk
Dahwg
Tucson, AZ
Those are FRS/GMRS shared frequencies. They are not FRS only frequencies.
FRS/GMRS combined channel chart - The RadioReference Wiki
Of course! This radio is too high power and has a removable antenna -only in other words, a real GMRS radio before the dreaded bubble pack came along!
The FRS -only frequencies are on the interstitials of the repeater input frequencies. Why would you allow a radio capable of more than .5 watts to muck with people's repeater.
This setup is perfect for GMRS. My old iCom F21GM and my iCom F4t are both set up this way.
Hans13
Yep. In the context of what you were quoting and replying to, I couldn't tell if you knew that. :)
Dahwg
Tucson, AZ
I re-read the thread and realized I had it confused with another thread concerning these radios. On that thread the individual was stating that the radio was useless to him because the shared GMRS/FRS frequencies were not available. That's what I get for posting so late at night.
bill4long
Indianapolis
Page 34
You are likewise mistaken. Those are shared FRS/GMRS frequencies. He said, "This Baofeng radio is unable to transmit on the shared FRS channels."
You are not following the thread closely.
