Macom M7100 Carrier Detect
Firzen
Hello, I'm trying to do simple crossband VHF<>UHF repeater using two Macom M7100 radios.
Is there any way to achive CARRIER/TALKGROUP detect LOW/HIGH signal on DB37 back connector?
towersites
Denver, CO
Yes, has to be steered to out1 or out 2 in the programming.
Firzen
The solution is quite simple, first in the RPM External Output Line 1 or 2 should be set to External Mute (Low or High depedns on needs) and It's done!
