Maplehurst Milton
Pyr8
Mandalore system :|]
Gearjam said:
Thanks PYR ...But I need the file...Its the only way I know how to load It In the scanner.
And yes I have arc996 and I'm a premium Member
Just use ARC and download directly to your scanner from the RR database! No need to have a separate file as ARC will create one for you!
Gearjam
Ontario Can.
It sounds easy...for some reason It never works for me....the conv. no problem...but the talk group stuff...gives me a hard time
exkalibur
York, Ontario
Might I suggest you learn how to actually program the scanner instead of relying on the goodness of someone else to have a file prepared?
It's really not a big deal - I programmed everything within a 300km radius of Toronto into a 396 in less than 4 hours.
Pyr8
In all fairness, how i learned was to take a look at a "prefabbed" file....made understanding how its all put together a little easier! :)
Muxlow
Super Secret
Middlesex County
I have never herd anythign on the corectional talk groups.. Only on the common UHF channels
mikewazowski
Forums Manager
Oot and Aboot
I hear activity on a daily basis on Fleetnet from the Correctional Facility near me.
Keep in mind that the only time Fleetnet is used is when a vehicle is off the grounds.
All internal communications are on UHF.
411.7375Mhz seems to be the common channel for most facilities.
Muxlow
Super Secret
Middlesex County
Guess no vans ever leave windsor, chatham or sarnia jails:(
And the UHF portables put out such a low wattage i can only hear them when im semi around the jails
Gearjam
Ontario Can.
exkalibur: I have been reading the manual that came with the 996...also the butel arc 996 since Christmas day...I'm Not relying on other members...I was just asking for a bit of help...Me being a retired Iron worker never touch a Computer until 5 yrs ago ...There was no Auto cad...all drawings were drawn on a old fashion drafting table.
I can remember many days In My career...there were young welders who came fresh out of collage with a welder/fitter diploma...and they just could not get the hang of welding pipe...they read all the books spent many hrs of welding In school...and they still could not weld very good at all...but they tried and tried. I have taken many of these young guys...who had a good attitude and wanted to learn...and I turned them In to top notch welders...some went In there own business and are still very successful...sometimes It takes a more experienced person to see what the other person Is doing wrong...you maybe able to program your 396 In 4 hrs...But I don't think you could connect or fabricate as much steel as I could In 4 hrs ...Its not really a big deal to help someone out.
mikewazowski
Forums Manager
Oot and Aboot
I think the big problem is Maplehurst only has a couple of channels and nobody would bother making up a file for a system that small.
It's much simpler to just to program it in by hand then take the time to make up the file.
Just hit hold and enter the frequency given above. It should ask if you want to Quick Save the frequency. Just answer yes and you're done.
For somebody just starting out, you've probably just bought yourself the most complicated scanner on the market today.
Gearjam
Ontario Can.
Thanks there Mike...I can see now that there just on the conventional freqs...I was thinking that they would be on a trunk system...Thanks for the tip and your correct on this 996...there's a lot that goes on In that little bearcat box
Cheers
frankh
where they used to build cars
If listening to them bus bodies around is your thing, it can usually be heard on the Chatham wide area talk group. The Windsor jail talk group seems to be used mostly as a car to car channel, but is rarely used.
Muxlow
Super Secret
Middlesex County
I have trunker and unitrunker running all the time and i have a log of maybe 20 times the windsor Tg has been used.. and 6 for chatham. and its been running for 3 months
never herd them talk on it.
only on uhf and vhf... maybe no one gets transfered anyplace
