Miami Tower
fireant
Copland
My experience has been that the 325P2 does not do well on Phase 2 systems. I would look into the SDS line or a Unication G4 or 5.
GeoFenceFound
Guthrie, OK
Ok thanks for the update . Will the BCD 325P2 work for me ?
if you are wanting traffic from the miami site your 996xt will work just fine assuming that tower isnt being used for phase two audio. If your listening to OKWIN then your 996xt will work just fine.
Yes, the BCD 325P2 will work and will also do phase two audio.
EDIT: refer to above posts on the quality of this scanner for phase two audio. I havent used this scanner for any of the SDS scanners yet. I personally use 536/436 HP still
peterjmag
Tulsa, OK
KOK5CY
To answer your original question, yes any scanner that can do Phase 1 will work just fine on OKWIN and the Miami Tower.
Phase 1 Scanners
Pro-197
GRE PSR-600
RS Pro-652
Whistler 1065 which is what I am using here in Tulsa.
BCT 996
etc.
Everyone is just saying that if you want to spend a little more money and get a Phase 2 scanner then my all means do so. As for the current state of the new system any Phase 1 scanner will work just fine. Just make sure you have a really good antenna. Remember with digital it's all or nothing. Since you will be monitoring a single site system P25 distortion should not be a problem for you.
I vote for the PSR-600, RS Pro-197, RS Pro-652, or the Whistler 1065. All 4 are identical as well as easier to program and less money. If the state does upgrade to Phase 2 in the future than yes you will will need to get a scanner that will scan Phase 2. Hope this helps.
KOK5CY
Mannford
I decided to go with the GRE PSR-600 . I wanted to thank everyone for your help and support and especially the last guy that listed the models to look at and which ones that support phase 1 . I should be in business in a few days . My antenna is high enough to receive the Miami trunked system tower .
Thanks again for your help with this matter .
peterjmag
Tulsa, OK
Your welcome sir! I'm glad I could help. Welcome to digital. Good choice on the PSR-600. I look forward to what you will hear in the future. Happy scanning...
wx5uif
Broken Arrow, OK
Looking through 800 today and see that Pryor is now P25. They've been upgrading sites like crazy that last few weeks.
peterjmag
Tulsa, OK
Yes they have. I too can confirm Pryor is complete. I have seen in other threads that they are busy in central Oklahoma as well. Glad to hear they are moving along.
GeoFenceFound
Guthrie, OK
I assume the Type II TGs are still being used/patched?
KOK5CY
Mannford
I took the PSR 600 to radio shack this morning and requested them to upload the Miami Tower and grda and Craig county and anything on the state system . Well I get home and come to find out they put the Jay tower in and I can't receive the tower . I managed to put in the Miami Tower and it seems to work but I don't see any radio IDs . I do see the P25 info . Who else can reprogram this unit ? . I'll be willing to pay for the programming . I can't drive to far but I occasionally drive to Claremore to visit my parents .
Anyone out there to help out ?
KOK5CY
Mannford
I decided to take it back to radio shack and explained what I wanted and that the Jay tower was to far away from me to receive and to upload the Miami Tower and good news is no charge to fix it .
KOK5CY
Mannford
Now I'm not receiving Ottawa county sheriff department . If I knew the TG # I'd just add it . But the the database doesn't show either .
